MURF1620CTHC0G
MURF1620CTHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY GP 200V ITO-220AB
MURF1620CTHC0G 数据手册
MURF1620CT – MURF1660CT Taiwan Semiconductor 16A, 200V - 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ultra fast recovery times Popular ITO-220AB Package High temperature glass passivated chip junction High voltage capability to 600 volts UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 16 A VRRM 200 - 600 V IFSM 100 A TJ MAX 150 °C Package ITO-220AB Configuration Dual dies APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.82g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device MURF MURF MURF 1620CT 1640CT 1660CT MURF 1620CT MURF 1640CT MURF 1660CT UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 16 A IFSM 100 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: K2105 MURF1620CT – MURF1660CT Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL MURF1620CT Junction-to-case thermal resistance MURF1640CT MURF1660CT RӨJC TYP UNIT 3 °C/W 2 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) TYP MAX UNIT MURF1620CT - 0.975 V MURF1640CT IF = 8A,TJ = 25°C - 1.300 V - 1.500 V - 0.895 V MURF1640CT IF = 8A,TJ = 125°C - 1.100 V MURF1660CT - 1.200 V MURF1620CT - 5 µA - 10 µA - 250 µA - 500 µA - 25 ns - 50 ns MURF1660CT SYMBOL VF MURF1620CT MURF1640CT TJ = 25°C Reverse current @ rated VR per diode (2) MURF1660CT IR MURF1620CT MURF1640CT TJ = 125°C MURF1660CT MURF1620CT Reverse recovery time MURF1640CT MURF1660CT IF = 0.5A , IR = 1.0A Irr = 0.25A trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MURF16xCT ITO-220AB 50 / Tube MURF16xCTH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 200V(MURF1620CT) to 600V(MURF1660CT) 2. “H” means AEC-Q101 qualified 2 Version: K2105 MURF1620CT – MURF1660CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 DC 16 CAPACITANCE (pF) 12 SQUARE WAVE 8 100 4 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 1 150 10 CASE TEMPERATURE (°C) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 10 TJ=100°C 1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 100 10 UF1DLW 1 10 TJ=100°C TJ=125°C TJ=25°C 0.1 1 TJ=25°C 0.01 0.1 0.001 0.4 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs Pulse width 1% duty cycle 0.40.6 0.5 0.60.8 0.7 1.0 0.9 0.8 11.2 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 120 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 0.1 100 REVERSE VOLTAGE (V) 100 8.3ms single half sine wave 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 20 Version: K2105 1.2 MURF1620CT – MURF1660CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2105 MURF1620CT – MURF1660CT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2105 MURF1620CT – MURF1660CT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2105
MURF1620CTHC0G 价格&库存
很抱歉,暂时无法提供与“MURF1620CTHC0G”相匹配的价格&库存,您可以联系我们找货
