TSS83L45 MXG
TSS83L45 MXG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD128
    DIODE SCHOTTKY 45V 3A SOD128
TSS83L45 MXG 数据手册
TSS83L45 Taiwan Semiconductor 3A, 45V Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Low power loss, high efficiency Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 3 A VRRM 45 V IFSM 30 A TJ MAX 150 °C Package SOD-128 Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: SOD-128 Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 0.028g (approximately) SOD-128 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSS83L45 UNIT 83L45 Repetitive peak reverse voltage VRRM 45 V Reverse voltage, total rms value VR(RMS) 32 V IF 3 A IFSM 30 A IRSM 10 A dV/dt 10,000 V/µs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load (1) Non-repetitive reverse current surge peak Critical rate of rise of off-state voltage Notes: 1. Pulse / period : 2us / 1000us, pulse no. : 10 times 1 Version: D2109 TSS83L45 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 23 °C/W Junction-to-ambient thermal resistance RӨJA 75 °C/W Junction-to-case thermal resistance RӨJC 25 °C/W Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 1A, TJ = 25°C Forward voltage per diode (1) IF = 3A, TJ = 25°C IF = 1A, TJ = 125°C VF IF = 3A, TJ = 125°C Reverse current @ rated VR (2) Junction capacitance TJ = 25°C IR TJ = 125°C 1MHz, VR = 4.0V CJ TYP MAX UNIT 0.39 0.47 V 0.50 0.56 V 0.29 0.36 V 0.44 0.50 V - 500 μA - 20 mA 220 - pF Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSS83L45 SOD-128 14,000 / Tape & Reel 2 Version: D2109 TSS83L45 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 3 CAPACITANCE (pF) A AVERAGE FORWARD CURRENT (A) 4 2 1 f=1.0MHz Vsig=50mVp-p 0 30 60 90 120 10 150 1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics Fig.4 Typical Forward Characteristics 100 10 TJ=125°C 1 0.1 0.01 TJ=25°C 0.001 10 10 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) 100 20 30 40 50 60 70 80 90 100 100 10 TJ=125°C TJ=25°C 1 Pulse width 300μs 1% duty cycle 0.1 0.1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.3 0.5 0.7 0.9 1.1 1.3 1.5 FORWARD VOLTAGE (V) 3 Version: D2109 TSS83L45 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-128 SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N = Marking Code YW = Date Code F = Factory Code 4 Version: D2109 TSS83L45 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: D2109
TSS83L45 MXG 价格&库存
很抱歉,暂时无法提供与“TSS83L45 MXG”相匹配的价格&库存,您可以联系我们找货
