S3A – S3M
Taiwan Semiconductor
3A, 50V - 1000V Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
High current capability
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
50 - 1000
V
IFSM
100
A
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
S3A
S3B
S3D
S3G
S3J
S3K
S3M UNIT
S3A
S3B
S3D
S3G
S3J
S3K
S3M
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
Forward current
Peak forward surge current, 8.3ms
single half sine wave superimposed
on rated load
Junction temperature
IF
3
A
IFSM
100
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: N2102
S3A – S3M
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
13
°C/W
Junction-to-ambient thermal resistance
RӨJA
47
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
Forward voltage
(1)
Reverse current @ rated VR
IF = 3A, TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
TJ = 25°C
SYMBOL
TYP
MAX
UNIT
VF
1.15
V
10
µA
250
µA
CJ
60
pF
trr
1500
ns
IR
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S3x
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(S3A) to 1000V(S3M)
2
Version: N2102
S3A – S3M
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
3
CAPACITANCE (pF)
2
1
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
1
TJ=25°C
40
50
60
70
80
90
100
10 10
UF1DLW
1
TJ=125°C
TJ=25°C
10.1
0.01
0.1
0.001
0.6
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.8
0.4
0.5
1.0
0.6
0.7
1.2
0.8
0.9
1.4
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
120
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
100
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
0.1
10
(A)
AVERAGE FORWARD CURRENT (A)
4
8.3ms single half sine wave
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: N2102
1.2
S3A – S3M
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: N2102
S3A – S3M
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: N2102
S3A – S3M
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: N2102
很抱歉,暂时无法提供与“S3BHM6G”相匹配的价格&库存,您可以联系我们找货
