SFAS808GHMNG
SFAS808GHMNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    DIODE GEN PURP 600V 8A TO263AB
SFAS808GHMNG 数据手册
SFAS801G – SFAS808G Taiwan Semiconductor 8A, 50V - 600V Super Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement High efficiency, low VF High surge current capability Low power loss Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 8 A VRRM 50 - 600 V IFSM 125 A TJ MAX 150 °C 2 Package TO-263AB (D PAK) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-263AB (D PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.33g (approximately) 2 TO-263AB (D PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SFAS 801G SFAS 801G SFAS 802G SFAS 802G SFAS 803G SFAS 803G SFAS 804G SFAS 804G SFAS 805G SFAS 805G VRRM 50 100 150 200 300 400 500 600 V VR(RMS) 35 70 105 140 210 280 350 420 V SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SFAS SFAS SFAS UNIT 806G 807G 808G SFAS SFAS SFAS 806G 807G 808G IF 8 A IFSM 125 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: N2103 SFAS801G – SFAS808G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2.2 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) Junction capacitance Reverse recovery time CONDITIONS SFAS801G SFAS802G SFAS803G SFAS804G I = 8A, TJ = 25°C SFAS805G F SFAS806G SFAS807G SFAS808G TJ = 25°C TJ = 100°C SFAS801G SFAS802G SFAS803G SFAS804G SFAS805G 1MHz, VR = 4.0V SFAS806G SFAS807G SFAS808G IF = 0.5A, IR = 1.0A Irr = 0.25A SYMBOL TYP MAX UNIT - 0.95 V - 1.30 V - 1.70 V - 10 µA - 400 µA 80 - pF 60 - pF - 35 ns VF IR CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) SFAS8xG PACKAGE 2 TO-263AB (D PAK) PACKING 800 / Tape & Reel Notes: 1. “x” defines voltage from 50V(SFAS801G) to 600V(SFAS808G) 2 Version: N2103 SFAS801G – SFAS808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 90 8 CAPACITANCE (pF) 6 4 2 SFAS801G - SFAS804G 80 SFAS805G - SFAS808G 70 60 50 f=1.0MHz Vsig=50mVp-p 40 0 25 50 75 100 125 1 150 10 CASE TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=100°C 10 1 TJ=25°C 0.1 20 30 40 50 60 70 80 90 100 1000 10 SFAS805G - SFAS806G UF1DLW 100 1 SFAS801G - SFAS804G TJ=125°C 10 0.1 1 0.01 TJ=25°C SFAS807G - SFAS808G Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 150 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 10 8.3ms single half sine wave 125 100 75 50 25 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: N2103 1.2 SFAS801G – SFAS808G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: N2103 SFAS801G – SFAS808G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-263AB (D PAK) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: N2103 SFAS801G – SFAS808G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: N2103
SFAS808GHMNG 价格&库存
很抱歉,暂时无法提供与“SFAS808GHMNG”相匹配的价格&库存,您可以联系我们找货
