1PGSMB5955HR5G
1PGSMB5955HR5G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE ZENER 180V 3W DO214AA
1PGSMB5955HR5G 数据手册
1PGSMB5926 – 1PGSMB5956 Taiwan Semiconductor 3W, 11V - 200V Surface Mount Zener Diode FEATURES ● ● ● ● ● ● KEY PARAMETERS Photo Glass passivated chip junction Ideal for automated placement Low inductance Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 11 - 200 V Test current IZT 1.9 - 34.1 mA Ptot 3 W TJ MAX 175 °C Package DO-214AA (SMB) Configuration Single die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.100g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER DC power dissipation at TL=75°C, measure at zero lead length (Note 1) derate above 75°C SYMBOL VALUE UNIT Ptot 3 W TJ -55 to +175 °C TSTG -55 to +175 °C SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 21 °C/W Junction-to-ambient thermal resistance RӨJA 59 °C/W Junction-to-case thermal resistance RӨJC 23 °C/W Junction temperature Storage temperature Notes: 1. Mounted on Cu-Pad size 10mm x 10mm on PCB THERMAL PERFORMANCE PARAMETER Thermal Performance Note: Units mounted on PCB (10mm x 10mm Cu pad test board) 1 Version: C2102 1PGSMB5926 – 1PGSMB5956 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Device (Note 1) Device Marking Code Nominal Zener Voltage Min Test Zener Impedance (Note 3) current Vz@Iz IZT ZZT @ IZT V Nom (Note 2) mA Ω ZZK@IZK Ω mA Leakage Current Maximum DC Zener Current IR@VR IZM μA V mA(DC) Max 1PGSMB5926 P926B 10.45 11 11.55 34.1 5.5 550 0.25 1 8.4 136 1PGSMB5927 P927B 11.40 12 12.60 31.2 6.5 550 0.25 1 9.1 125 1PGSMB5928 P928B 12.35 13 13.65 28.8 7.0 550 0.25 1 9.9 115 1PGSMB5929 P929B 14.25 15 15.75 25.0 9.0 600 0.25 1 11.4 100 1PGSMB5930 P930B 15.20 16 16.80 23.4 10.0 600 0.25 1 12.2 94 1PGSMB5931 P931B 17.10 18 18.90 20.8 12.0 650 0.25 1 13.7 83 1PGSMB5932 P932B 19.00 20 21.00 18.7 14.0 650 0.25 1 15.2 75 1PGSMB5933 P933B 20.90 22 23.10 17.0 17.5 650 0.25 1 16.7 68 1PGSMB5934 P934B 22.80 24 25.20 15.6 19 700 0.25 1 18.2 63 1PGSMB5935 P935B 25.65 27 28.35 13.9 23 700 0.25 1 20.6 56 1PGSMB5936 P936B 28.50 30 31.50 12.5 26 750 0.25 1 22.8 50 1PGSMB5937 P937B 31.35 33 34.65 11.4 33 800 0.25 1 25.1 45 1PGSMB5938 P938B 34.20 36 37.80 10.4 38 850 0.25 1 27.4 42 1PGSMB5939 P939B 37.05 39 40.95 9.6 45 900 0.25 1 29.7 38 1PGSMB5940 P940B 40.85 43 45.15 8.7 53 950 0.25 1 32.7 35 1PGSMB5941 P941B 44.65 47 49.35 8.0 67 1000 0.25 1 35.8 32 1PGSMB5942 P942B 48.45 51 53.55 7.3 70 1100 0.25 1 38.8 29 1PGSMB5943 P943B 53.20 56 58.80 6.7 86 1300 0.25 1 42.6 27 1PGSMB5944 P944B 58.90 62 65.10 6.0 100 1500 0.25 1 47.1 24 1PGSMB5945 P945B 64.60 68 71.40 5.5 120 1700 0.25 1 51.7 22 1PGSMB5946 P946B 71.25 75 78.75 5.0 140 2000 0.25 1 56.0 20 1PGSMB5947 P947B 77.90 82 86.10 4.6 160 2500 0.25 1 62.2 18 1PGSMB5948 P948B 86.45 91 95.55 4.1 200 3000 0.25 1 69.2 16 1PGSMB5949 P949B 95.00 100 105.00 3.7 250 3100 0.25 1 76.0 15 1PGSMB5950 P950B 104.50 110 115.50 3.4 300 4000 0.25 1 83.6 13 1PGSMB5951 P951B 114.00 120 126.00 3.1 360 4500 0.25 1 91.2 12 1PGSMB5952 P952B 123.50 130 136.50 2.9 450 5000 0.25 1 98.8 11 1PGSMB5953 P953B 142.50 150 157.50 2.5 600 6000 0.25 1 114.0 10 1PGSMB5954 P954B 152.00 160 168.00 2.3 700 6500 0.25 1 121.6 9 1PGSMB5955 P955B 171.00 180 189.00 2.1 900 7000 0.25 1 136.8 8 1PGSMB5956 P956B 190.00 200 210.00 1.9 1200 8000 0.25 1 152.0 7 Notes: 1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5% 2. Zener voltage (Vz) measurement Nominal Zener voltage is measured with the device junction in thermal equilibrium with ambient temperature 25°C 3. Zener impedance (Zz) derivation : ZZT and ZZK are measured by dividing the AC voltage drop across the device by the AC current applied. 4. The specified limits are for Iz (AC) = 0.1 Iz (DC) with the AC frequency = 60Hz 2 Version: C2102 1PGSMB5926 – 1PGSMB5956 Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING 1PGSMB59x DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 11V(1PGSMB5926) to 200V(1PGSMB5956) 3 Version: C2102 1PGSMB5926 – 1PGSMB5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Steady State Power Derating Fig.2 Typical Junction Capacitance 1000 1PGSMB5927 3 CAPACITANCE (pF) TOTAL POWER DISSIPATION (W) 4 2 1 100 1PGSMB5939 1PGSMB5945 10 f=1.0MHz Vsig=50mVp-p 0 1 25 50 75 100 125 150 175 1 10 100 REVERSE VOLTAGE (V) LEAD TEMPERATURE (°C) Fig.3 Typical Zener Impedance Zz - DYNAMIC IMPEDANCE (Ω) 10000 1000 100 1PGSMB5945 10 1PGSMB5939 1PGSMB5927 1 0.1 1 10 100 Iz - ZENER TEST CURRENT (mA) 4 Version: C2102 1PGSMB5926 – 1PGSMB5956 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: C2102 1PGSMB5926 – 1PGSMB5956 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2102
1PGSMB5955HR5G 价格&库存
很抱歉,暂时无法提供与“1PGSMB5955HR5G”相匹配的价格&库存,您可以联系我们找货
