GBL01 D2G
GBL01 D2G
    TAIWANSEMICONDUCTOR(台半)
    SIP4
    BRIDGE RECT 1PHASE 100V 4A GBL
GBL01 D2G 数据手册
GBL005 – GBL10 Taiwan Semiconductor 4A, 50V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Ideal for printed circuit board High case dielectric strength Typical IR less than 0.1μA UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 4 A VRRM 50 - 1000 V IFSM 150 A TJ MAX 150 °C Package GBL Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: GBL Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 2.00g (approximately) GBL ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device GBL 005 GBL 01 GBL 02 GBL 04 GBL 06 GBL 08 GBL 10 UNIT GBL005 GBL01 GBL02 GBL04 GBL06 GBL08 GBL10 Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V 4 A 3 A IFSM 150 A It 2 93 As Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C Forward current TC = 50°C TA = 40°C Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
GBL01 D2G 价格&库存
很抱歉,暂时无法提供与“GBL01 D2G”相匹配的价格&库存,您可以联系我们找货
