SR2030 C0G
SR2030 C0G
    TAIWANSEMICONDUCTOR(台半)
    TO-220-3
    DIODE ARRAY SCHOTTKY 30V TO220AB
SR2030 C0G 数据手册
SR2020 – SR20150 Taiwan Semiconductor 20A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters PARAMETER VALUE UNIT IF 20 A VRRM 20 - 150 V IFSM 200 A TJ MAX 125, 150 °C Package TO-220AB Configuration Dual dies MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.80g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) SR SR SR SR SR SR SR SR PARAMETER SYMBOL UNIT 2020 2030 2040 2050 2060 2090 20100 20150 SR SR SR SR SR SR SR SR Marking code on the device 2020 2030 2040 2050 2060 2090 20100 20150 Repetitive peak reverse voltage VRRM 20 30 40 50 60 90 100 150 V Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature VR(RMS) 14 21 28 35 42 63 70 105 V IF 20 A IFSM 200 A dv/dt 10,000 V/μs TJ -55 to +125 TSTG -55 to +150 -55 to +150 1 °C °C Version: J2104 SR2020 – SR20150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 1 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER SR2020 SR2030 SR2040 SR2050 (1) Forward voltage per diode SR2060 SR2090 SR20100 SR20150 SR2020 SR2030 SR2040 SR2050 SR2060 SR2090 SR20100 SR20150 SR2020 SR2030 SR2040 Reverse current @ rated VR per SR2050 (2) diode SR2060 SR2090 SR20100 SR20150 SR2020 SR2030 SR2040 SR2050 SR2060 SR2090 SR20100 SR20150 Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms CONDITIONS IF = 10A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.90 V - 1.00 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR20x TO-220AB 50 / Tube SR20xH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 20V(SR2020) to 150V(SR20150) 2. “H” means AEC-Q101 qualified 2 Version: J2104 SR2020 – SR20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SR2050 - SR20150 20 CAPACITANCE (pF) 16 12 8 SR2020 - SR2040 1000 SR2020-2040 SR2050-20150 4 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 100 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 10 90 100 100 10 SR2020-2040 10 1 UF1DLW SR2050-2060 TJ=125°C TJ=25°C 0.1 SR2090-20100 1 SR20150 0.01 0.1 0.001 0.1 Pulse width 300μs 1% duty cycle Pulse width 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.3 0.4 0.5 0.7 0.5 0.6 0.7 0.9 0.8 1.1 0.9 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 240 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 24 200 8.3ms single half sine wave 160 120 80 40 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: J2104 1.2 SR2020 – SR20150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: J2104 SR2020 – SR20150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: J2104 SR2020 – SR20150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: J2104
SR2030 C0G 价格&库存
很抱歉,暂时无法提供与“SR2030 C0G”相匹配的价格&库存,您可以联系我们找货
