MBRF3035CT – MBRF30200CT
Taiwan Semiconductor
30A, 35V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
35 - 200
V
IFSM
200
A
TJ MAX
150
°C
APPLICATIONS
Package
ITO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF
PARAMETER
SYMBOL 3035
CT
3050
3060
CT
CT
CT
3090 30100 30150 30200 UNIT
CT
CT
CT
CT
3035
3045
3050
3060
CT
CT
CT
CT
CT
CT
CT
CT
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total
rms value
Forward current
Surge peak forward
current, 8.3ms single half
sine wave superimposed
on rated load
Peak repetitive reverse
(1)
surge current
3045
VRRM
35
45
50
60
90
100
150
200
V
VR(RMS)
24
31
35
42
63
70
105
140
V
IF
30
A
IFSM
200
A
IRRM
1.0
0.5
1
A
Version: M2105
PARAMETER
SYMBOL 3035
CT
Peak repetitive forward
current (Rated VR,
Square wave, 20KHz)
Critical rate of rise
of off-state voltage
Junction temperature
Storage temperature
Notes:
1. tp = 2.0μs, 1.0KHz
3045
3050
3060
CT
CT
CT
CT
CT
CT
CT
IFRM
30
A
dv/dt
10,000
V/µs
TJ
TSTG
-55 to +150
-55 to +150
°C
°C
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
4
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MBRF3035CT
MBRF3045CT
MBRF3050CT
MBRF3060CT
MBRF3090CT
MBRF30150CT
Forward voltage per diode
MBRF30200CT
MBRF3045CT
MBRF3050CT
MBRF3090CT
UNIT
0.70
V
0.75
V
0.84
V
0.95
V
0.82
V
0.90
V
0.94
V
1.05
V
VF
MBRF3035CT
MBRF3060CT
MAX
IF = 15A,TJ = 25°C
MBRF30100CT
(1)
TYP
IF = 30A,TJ = 25°C
MBRF30100CT
MBRF30150CT
MBRF30200CT
2
Version: M2105
PARAMETER
CONDITIONS
SYMBOL
MBRF3035CT
MBRF3045CT
MBRF3050CT
MBRF3060CT
MBRF3090CT
MBRF30150CT
MBRF30200CT
MBRF3045CT
MBRF3050CT
MBRF3090CT
UNIT
0.60
V
0.65
V
0.70
V
0.80
V
0.73
V
0.78
V
0.82
V
0.92
V
200
µA
mA
15
mA
10
mA
VF
MBRF3035CT
MBRF3060CT
MAX
IF = 15A,TJ = 125°C
MBRF30100CT
(1)
TYP
IF = 30A,TJ = 125°C
MBRF30100CT
MBRF30150CT
MBRF30200CT
MBRF3035CT
MBRF3045CT
MBRF3050CT
MBRF3060CT
MBRF3090CT
TJ = 25°C
MBRF30100CT
MBRF30150CT
Reverse current @ rated VR per MBRF30200CT
(2)
MBRF3035CT
diode
IR
MBRF3045CT
MBRF3050CT
MBRF3060CT
MBRF3090CT
TJ = 125°C
MBRF30100CT
MBRF30150CT
MBRF30200CT
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBRF30xCT
ITO-220AB
50 / Tube
MBRF30xCTH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBRF3035CT) to 200V(MBRF30200CT)
2. “H” means AEC-Q101 qualified
3
Version: M2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
MBRF3035CT-3045CT
30
MBRF3050CT-3060CT
25
CAPACITANCE (pF)
10
1000
100
MBRF3090CT-30200CT
5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
TJ=75°C
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100 10
MBRF3035CT-3045CT
1
MBRF3050CT-3060CT
UF1DLW
10
TJ=125°C
TJ=25°C
0.1
MBRF3090CT-30100CT
1
0.01
MBRF30150CT-30200CT
0.1
0.001
0.0 0.3 0.20.4 0.40.5 0.6
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
Pulse width
1% duty cycle
0.8
0.7
1.0
0.8
1.2
0.9
11.4
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
240
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
MBRF3035CT-3045CT
MBRF3050CT-30200CT
0.01
100
Fig.4 Typical Forward Characteristics
1000
1
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
1
(A)
AVERAGE FORWARD CURRENT (A)
35
200
8.3ms single half sine wave
160
120
80
40
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: M2105
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: M2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: M2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: M2105
很抱歉,暂时无法提供与“MBRF3090CT C0G”相匹配的价格&库存,您可以联系我们找货
