MBRS2035CT – MBRS20150CT
Taiwan Semiconductor
20A, 35V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
A
VRRM
35 - 150
V
IFSM
150
A
TJ MAX
150
APPLICATIONS
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.37g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse
(1)
surge current
Peak repetitive forward
current (Rated VR, Square
wave, 20KHz)
Critical rate of rise of offstate voltage
Notes:
1. tp = 2.0μs, 1.0KHz
MBRS
SYMBOL 2035
CT
MBRS
2035CT
MBRS
2045
CT
MBRS
2045CT
MBRS
2050
CT
MBRS
2050CT
MBRS
2060
CT
MBRS
2060CT
MBRS MBRS MBRS
2090 20100 20150 UNIT
CT
CT
CT
MBRS MBRS
MBRS
2090CT 20100CT 20150CT
VRRM
35
45
50
60
90
100
150
V
VR(RMS)
24
31
35
42
63
70
105
V
IF
A
IFSM
150
A
IRRM
1
0.5
A
IFRM
A
dv/dt
10,000
V/μs
1
Version: N2103
PARAMETER
MBRS MBRS MBRS MBRS MBRS MBRS
SYMBOL 2035 2045 2050 2060 2090 20100
CT
CT
CT
CT
CT
CT
MBRS
20150 UNIT
CT
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
RӨJC
2
°C/W
MBRS2035CT
MBRS2045CT
MBRS2050CT
MBRS2060CT
MBRS2090CT
MBRS20100CT
MBRS20150CT
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per
(1)
diode
CONDITIONS
MBRS2035CT
MBRS2045CT
MBRS2050CT
MBRS2060CT
MBRS2090CT
MBRS20100CT
MBRS20150CT
MBRS2035CT
MBRS2045CT
MBRS2050CT
MBRS2060CT
MBRS2090CT
MBRS20100CT
MBRS20150CT
MBRS2035CT
MBRS2045CT
MBRS2050CT
MBRS2060CT
MBRS2090CT
MBRS20100CT
MBRS20150CT
MBRS2035CT
MBRS2045CT
MBRS2050CT
MBRS2060CT
MBRS2090CT
MBRS20100CT
MBRS20150CT
SYMBOL
IF = 10A, TJ = 25°C
IF = 20A, TJ = 25°C
VF
IF = 10A, TJ = 125°C
IF = 20A, TJ = 125°C
2
TYP
MAX
UNIT
0.65
V
0.80
V
0.85
V
0.99
V
0.84
V
0.95
V
0.95
V
1.23
V
0.57
V
0.70
V
0.75
V
0.87
V
0.72
V
0.85
V
0.85
V
1.10
V
Version: N2103
PARAMETER
Reverse current @ rated VR
(2)
per diode
CONDITIONS
MBRS2035CT
MBRS2045CT
MBRS2050CT
MBRS2060CT TJ = 25°C
MBRS2090CT
MBRS20100CT
MBRS20150CT
MBRS2035CT
MBRS2045CT
MBRS2050CT
MBRS2060CT TJ = 125°C
MBRS2090CT
MBRS20100CT
MBRS20150CT
SYMBOL
TYP
MAX
UNIT
100
µA
15
mA
10
mA
5
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
MBRS20xCT
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 35V(MBRS2035CT) to 150V(MBRS20150CT)
3
Version: N2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
15
10
MBRS2035CT - 2045CT
1000
MBRS2050CT - 20150CT
5
f=1.0MHz
Vsig=50mVp-p
100
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
TJ=75°C
INSTANTANEOUS FORWARD CURRENT (A)
1
0.1
MBRS2035CT-2045CT
MBRS2050CT-20150CT
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100 10
10
TUF1DLW
J=125°C
1
TJ=125°C
0.1
TJ=25°C
TJ=25°C
2035CT-2045CT
2050CT-2060CT
2090CT-20150CT
Pulse width 300μs
1% duty cycle
Pulse width
1
0.01
0.1
0.001
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
TJ=125°C
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
25
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: N2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: N2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: N2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: N2103
很抱歉,暂时无法提供与“MBRS2050CT MNG”相匹配的价格&库存,您可以联系我们找货
