UGF1005GHC0G
UGF1005GHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY GP 300V ITO-220AB
UGF1005GHC0G 数据手册
UGF1004G – UGF1008G Taiwan Semiconductor 10A, 200V - 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High efficiency, low VF High current capability High surge current capability Low power loss UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 10 A VRRM 200 - 600 V IFSM 70 A TJ MAX 150, 175 °C Package ITO-220AB Configuration Dual dies APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device UGF UGF UGF UGF UGF 1004G 1005G 1006G 1007G 1008G UGF UGF UGF UGF UGF 1004G 1005G 1006G 1007G 1008G UNIT Repetitive peak reverse voltage VRRM 200 300 400 500 600 V Reverse voltage, total rms value VR(RMS) 140 210 280 350 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 10 A IFSM 70 A TJ -55 to +175 -55 to +150 °C Storage temperature TSTG -55 to +175 -55 to +150 °C 1 Version: F2105 UGF1004G – UGF1008G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 6 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL UGF1004G UGF1005G (1) Forward voltage per diode UGF1006G IF = 5A, TJ = 25°C VF UGF1007G UGF1008G Reverse current @ rated VR per diode (2) TJ = 25°C TJ = 125°C IR TYP MAX UNIT - 0.95 V - 1.25 V - 1.70 V - 10 µA - 100 µA - 20 ns - 25 ns UGF1004G UGF1005G Reverse recovery time UGF1006G UGF1007G IF = 0.5A , IR = 1.0A Irr = 0.25A UGF1008G trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING UGF10xG ITO-220AB 50 / Tube UGF10xGH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 200V(UGF1004G) to 600V(UGF1008G) 2. “H” means AEC-Q101 qualified 2 Version: F2105 UGF1004G – UGF1008G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 UGF1004G-06G 10 CAPACITANCE (pF) 8 6 UGF1007G-08G 4 100 10 2 0 25 50 75 100 125 150 f=1.0MHz Vsig=50mVp-p 1 175 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 10 90 100 100 10 UF1DLW 1 10 TJ=125°C TJ=125°C TJ=25°C 0.1 TJ=25°C 1 UGF1004G UGF1005G-06G UGF1007G-08G 0.01 0.1 0.001 0.2 0.30.4 0.4 0.6 0.5 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs Pulse width 1% duty cycle 1.0 0.6 1.2 0.7 1.4 0.8 1.60.91.8 1 2.0 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 80 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 1 10 REVERSE VOLTAGE (V) 70 8.3ms single half sine wave 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 12 Version: F2105 1.2 UGF1004G – UGF1008G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2105 UGF1004G – UGF1008G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: F2105
UGF1005GHC0G 价格&库存
很抱歉,暂时无法提供与“UGF1005GHC0G”相匹配的价格&库存,您可以联系我们找货
