MBR3035CT – MBR30150CT
Taiwan Semiconductor
30A, 35V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
35 - 150
V
IFSM
200
A
TJ MAX
150
°C
Package
TO-220AB
Configuration
Dual dies
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.90g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
MBR MBR MBR MBR
PARAMETER
SYMBOL 3035 3045 3050 3060
CT
CT
CT
CT
MBR
MBR
MBR
MBR
Marking code on the device
3035
3045
3050
3060
CT
CT
CT
CT
Repetitive peak reverse voltage
VRRM
35
45
50
60
Reverse voltage, total rms value
VR(RMS)
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse
(1)
surge current
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
Critical rate of rise of off-state
voltage
Junction temperature
IF
30
A
IFSM
200
A
Storage temperature
24
31
IRRM
35
MBR MBR MBR
3090 30100 30150 UNIT
CT
CT
CT
MBR
MBR
MBR
3090 30100 30150
CT
CT
CT
90
100
150
V
42
1
63
70
0.5
105
V
A
IFRM
30
A
dv/dt
10,000
V/μs
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: K2104
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
MBR3035CT
MBR3045CT
MBR3050CT
MBR3060CT
MBR3090CT
MBR30100CT
MBR30150CT
SYMBOL
TYP
UNIT
RӨJC
1.0
°C/W
RӨJC
1.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per
(1)
diode
Reverse current @
(2)
rated VR per diode
CONDITIONS
MBR3035CT
MBR3045CT
MBR3050CT
MBR3060CT
MBR3090CT
MBR30100CT
MBR30150CT
MBR3035CT
MBR3045CT
MBR3050CT
MBR3060CT
MBR3090CT
MBR30100CT
MBR30150CT
MBR3035CT
MBR3045CT
MBR3050CT
MBR3060CT
MBR3090CT
MBR30100CT
MBR30150CT
MBR3035CT
MBR3045CT
MBR3050CT
MBR3060CT
MBR3090CT
MBR30100CT
MBR30150CT
MBR3035CT
MBR3045CT
MBR3050CT
MBR3060CT
MBR3090CT
MBR30100CT
MBR30150CT
MBR3035CT
MBR3045CT
MBR3050CT
MBR3060CT
MBR3090CT
MBR30100CT
MBR30150CT
SYMBOL
IF = 15A, TJ = 25°C
IF = 30A, TJ = 25°C
VF
IF = 15A, TJ = 125°C
IF = 30A, TJ = 125°C
TJ = 25°C
TYP
MAX
UNIT
0.70
V
0.77
V
0.84
V
0.95
V
0.82
V
V
0.94
V
1.02
V
0.60
V
0.67
V
0.70
V
0.92
V
0.73
V
V
0.82
V
0.98
V
200
µA
100
µA
15
mA
10
mA
7.5
mA
5
mA
IR
TJ = 125°C
2
Version: K2104
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBR30xCT
TO-220AB
50 / Tube
MBR30xCTH
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBR3035CT) to 150V(MBR30150CT)
2. “H” means AEC-Q101 qualified
3
Version: K2104
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
30
MBR3035CT-3045CT
25
CAPACITANCE (pF)
10
MBR3050CT-3060CT
MBR3090CT-30150CT
1000
5
f=1.0MHz
Vsig=50mVp-p
100
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
MBR3035CT-3045CT
MBR3050CT-30150CT
TJ=125°C
0.1
TJ=75°C
TJ=25°C
0.01
0.001
10
40
50
60
70
80
90
100
100 10
10
UF1DLW
MBR3050CT-3060CT
1
MBR3035CT-3045CT
TJ=125°C
TJ=25°C
0.1
MBR30150CT
1
0.01
0.1
0.001
0.1
MBR3090CT-30100CT
Pulse width 300μs
1% duty cycle
Pulse width
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.3
0.4
0.5
0.5
0.6
0.7
0.7
0.8
0.9
0.9
1.1
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
225
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
(A)
AVERAGE FORWARD CURRENT (A)
35
200
175
150
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: K2104
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: K2104
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2104
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: K2104
很抱歉,暂时无法提供与“MBR3035CTHC0G”相匹配的价格&库存,您可以联系我们找货
