MBRF1535CT – MBRF15150CT
Taiwan Semiconductor
15A, 35V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
15
A
VRRM
35 - 150
V
IFSM
150
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
MBRF MBRF MBRF MBRF MBRF MBRF MBRF
PARAMETER
SYMBOL
1535
1545
1550
1560
CT
CT
CT
CT
1590 15100 15150 UNIT
CT
CT
CT
1535
1545
1550
1560
1590 15100 15150
CT
CT
CT
CT
CT
CT
CT
Marking code on the device
Repetitive peak reverse voltage
VRRM
35
45
50
60
90
100
150
V
Reverse voltage, total rms value
VR(RMS)
24
31
35
42
63
70
105
V
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive reverse surge
(1)
current
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
Critical rate of rise of off-state
voltage
IF
15
A
IFSM
150
A
IRRM
1.0
0.5
A
IFRM
15
A
dv/dt
10,000
V/µs
1
Version: J2105
PARAMETER
SYMBOL
Junction temperature
Storage temperature
Notes:
1. tp = 2.0μs, 1.0KHz
1535
1545
1550
1560
CT
CT
CT
CT
TJ
TSTG
CT
CT
CT
-55 to +150
-55 to +150
°C
°C
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
3.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MBRF1535CT
MBRF1545CT
MBRF1550CT
MBRF1560CT
MBRF1590CT
MBRF15150CT
MBRF1535CT
MBRF1545CT
MBRF1550CT
MBRF1590CT
(1)
MBRF15150CT
MBRF1545CT
MBRF1550CT
V
0.75
V
0.92
V
0.95
V
0.84
V
V
V
V
0.57
V
0.65
V
0.82
V
0.92
V
0.72
V
V
V
V
IF = 7.5A,TJ = 125°C
MBRF1590CT
MBRF15100CT
MBRF15150CT
MBRF1535CT
MBRF1545CT
MBRF1550CT
MBRF1560CT
VF
MBRF1535CT
MBRF1560CT
UNIT
IF = 15A,TJ = 25°C
MBRF15100CT
Forward voltage per diode
MAX
IF = 7.5A,TJ = 25°C
MBRF15100CT
MBRF1560CT
TYP
IF = 15A,TJ = 125°C
MBRF1590CT
MBRF15100CT
MBRF15150CT
2
Version: J2105
PARAMETER
CONDITIONS
SYMBOL
MBRF1535CT
MBRF1545CT
MBRF1550CT
MBRF1560CT
TJ = 25°C
IR
TYP
MAX
UNIT
500
µA
300
µA
100
µA
10
mA
7.5
mA
5
mA
MBRF1590CT
MBRF15100CT
Reverse current @ rated VR
per diode
(2)
MBRF15150CT
MBRF1535CT
MBRF1545CT
MBRF1550CT
MBRF1560CT
TJ = 125°C
MBRF1590CT
MBRF15100CT
MBRF15150CT
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBRF15xCT
ITO-220AB
50 / Tube
MBRF15xCTH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBRF1535CT) to 150V(MBRF15150CT)
2. “H” means AEC-Q101 qualified
3
Version: J2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
15
CAPACITANCE (pF)
10
5
MBRF1590CT-15150CT
1000
100
MBRF1535CT-1560CT
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
MBRF1535CT-1545CT
MBRF1550CT-15150CT
TJ=125°C
1
0.1
TJ=75°C
0.01
TJ=25°C
0.001
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
100010
100
1
MBRF1535CT-1545CT
MBRF1550CT-1560CT
UF1DLW
MBRF1590CT-15150CT
TJ=125°C
T =125°C
J
10
0.1
TJ=25°C
1
0.01
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
165
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
10
REVERSE VOLTAGE (V)
150
135
120
105
90
75
60
45
30
15
10
100
NUMBER OF CYCLES AT 60 Hz
4
(A)
AVERAGE FORWARD CURRENT (A)
Version: J2105
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: J2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: J2105
很抱歉,暂时无法提供与“MBRF1590CTHC0G”相匹配的价格&库存,您可以联系我们找货
