UGF8JDHC0G
UGF8JDHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE GEN PURP 600V 8A ITO220AC
UGF8JDHC0G 数据手册
UGF8JD Taiwan Semiconductor 8A, 600V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available High capability for high di/dt operation. High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application PARAMETER VALUE UNIT IF 8 A VRRM 600 V IFSM 100 A TJ MAX 150 °C Package ITO-220AC Configuration Single die MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device UGF8JD UNIT UGF8JD Repetitive peak revers voltage VRRM 600 V Reverse voltage total rms value VR(RMS) 420 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 8 A IFSM 100 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: D2105 UGF8JD Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 4 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 8A, TJ = 25°C (2) Reverse recovery time Reverse recovery charges TJ = 25°C TJ = 125°C IF = 0.5A, IR = 1.0A, Irr = 0.25A IF = 1A, VR = 30V dIF/dt = -50A/μs IF = 1A, VR = 400V dIF/dt = -200A/μs TJ = 125°C SYMBOL TYP MAX UNIT VF - 2.3 V - 0.5 µA - 100 µA trr 13 - ns trr - 30 ns Qrr 90 - nC IRM 5 5.5 A IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING UGF8JD ITO-220AC 50 / Tube UGF8JDH ITO-220AC 50 / Tube Notes: 1. “H” means AEC-Q101 qualified 2 Version: D2105 UGF8JD Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 8 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 10 6 4 100 2 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) 10 1 TJ=25°C 0.01 20 30 40 50 60 70 80 90 100 10 10 1 UF1DLW TJ=125°C TJ=125°C TJ=25°C 10.1 (A) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=25°C 0.01 Pulse width 300μs Pulse width 1% duty cycle 0.001 0.1 0.80.3 1 0.4 1.2 0.51.4 0.61.6 0.71.8 0.82 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.9 2.2 12.4 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 110 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 0.1 10 100 90 80 70 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: D2105 1.2 UGF8JD Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: D2105 UGF8JD Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: D2105
UGF8JDHC0G 价格&库存
很抱歉,暂时无法提供与“UGF8JDHC0G”相匹配的价格&库存,您可以联系我们找货
