HER201G – HER208G
Taiwan Semiconductor
2A, 50V - 1000V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 1000
V
IFSM
60
A
TJ MAX
150
°C
Package
DO-204AC (DO-15)
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: DO-204AC (DO-15)
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.400g (approximately)
DO-204AC (DO-15)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward
current, 8.3ms single half
sine wave superimposed
on rated load
Junction temperature
Storage temperature
SYMBOL
HER HER HER HER HER HER HER HER
UNIT
201G 202G 203G 204G 205G 206G 207G 208G
HER
HER
HER
HER
HER
HER
HER
HER
VRRM
50
100
200
300
400
600
800
1000
V
VR(RMS)
35
70
140
210
280
420
560
700
V
IF
2
A
IFSM
60
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: G2105
HER201G – HER208G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
60
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
Junction capacitance
Reverse recovery time
CONDITIONS
HER201G
HER202G
HER203G
HER204G
I = 2A, TJ = 25°C
HER205G F
HER206G
HER207G
HER208G
TJ = 25°C
TJ = 125°C
HER201G
HER202G
HER203G
HER204G
1MHz, VR = 4.0V
HER205G
HER206G
HER207G
HER208G
HER201G
HER202G
HER203G
HER204G IF = 0.5A, IR = 1.0A,
HER205G Irr = 0.25A
HER206G
HER207G
HER208G
SYMBOL
VF
IR
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
5
µA
150
µA
35
pF
pF
50
ns
75
ns
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
HER20xG
DO-204AC (DO-15)
3,500 / Tape & Reel
HER20xG A0G
DO-204AC (DO-15)
1,500 / Ammo box
HER20xGH
DO-204AC (DO-15)
3,500 / Tape & Reel
HER20xGHA0G
DO-204AC (DO-15)
1,500 / Ammo box
Notes:
1. "x" defines voltage from 50V (HER201G) to 1000V (HER208G)
2. “H” means AEC-Q101 qualified
2
Version: G2105
HER201G – HER208G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
HER201G-HER205G
CAPACITANCE (pF)
2
1
10
HER206G-HER208G
f=1.0MHz
Vsig=50mVp-p
25
50
75
100
125
150
1
10
AMBIENT TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
10
TJ=75°C
1
TJ=25°C
0.1
40
50
60
70
80
90
100
1010
HER201G-HER204G
UF1DLW
1
HER205G
TJ=125°C
TJ=25°C
10.1
HER206G-HER208G
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.40.3 0.6
0.4 0.8
0.5
1
0.6
1.2
0.7
1.4
0.8
1.6
0.9
11.8
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
70
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
3
60
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: G2105
1.2
HER201G – HER208G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: G2105
HER201G – HER208G
PACKAGE OUTLINE DIMENSIONS
DO-204AC (DO-15)
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: G2105
HER201G – HER208G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: G2105
很抱歉,暂时无法提供与“HER207G R0G”相匹配的价格&库存,您可以联系我们找货
