GBPC5004 T0G
GBPC5004 T0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    Square-4
    BRIDGE RECT 1P 400V 50A GBPC40
GBPC5004 T0G 数据手册
GBPC40, 50 SERIES Taiwan Semiconductor 40A, 50A, 50V - 1000V Standard Bridge Rectifier FEATURES KEY PARAMETERS ● Glass passivated chip junction ● Integrally molded heatsink provide very low thermal resistance for maximum heat dissipation ● Universal 4-way terminals: snap-on, wrap-around, solder or P.C. board mounting ● High surge current capability ● UL Recognized File # E-326243 ● RoHS Compliant PARAMETER VALUE UNIT IF 40, 50 A VRRM 50 - 1000 V IFSM 400 A TJ MAX 150 °C Package GBPC40 Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● AC to DC converter ~ MECHANICAL DATA ~ + ● Case: GBPC40 GBPC40-M: Terminal cathode parallel to anode ● Molding compound meets UL 94V-0 flammability rating ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 1A whisker test ● Mounting torque: 20 in-lbs maximum ● Polarity: As marked ● Weight: 17.30g (approximately) ─ + ─ ~ GBPC40 ~ GBPC40-M ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL 005 01 02 04 06 08 10 UNIT Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V 40 A 50 A IFSM 400 A It 2 664 As Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C Forward current GBPC40 GBPC50 Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
GBPC5004 T0G
物料型号:GBPC40, 50系列
器件简介:这是一系列标准桥式整流器,具有40A或50A的正向电流和50V至1000V的反向电压等级。
引脚分配:文档中没有提供具体的引脚分配图,但提到了通用的4向端子,可以进行卡扣式、环绕式、焊接或PCB板安装。
参数特性: - 正向电流(IF):40.50A - 反向电压(VRRM):50-1000V - 峰值正向浪涌电流(IFSM):400A - 最大结温(TJ MAX):150°C
功能详解:GBPC40, 50系列整流器具有玻璃钝化芯片结,集成的散热片提供非常低的热阻,以实现最大的散热效果。它们还具有高浪涌电流能力,并符合RoHS标准。
应用信息:适用于开关电源模式供应(SMPS)和交流转直流转换器(AC to DC converter)。
封装信息:提供了两种封装类型,GBPC40和GBPC40-M,其中GBPC40-M的端子阴极与阳极平行。封装材料符合UL 94V-0可燃性等级,端子为镀锡的哑光引线,可按照J-STD-002进行焊接。
GBPC5004 T0G 价格&库存
很抱歉,暂时无法提供与“GBPC5004 T0G”相匹配的价格&库存,您可以联系我们找货
GBPC5004 T0G
