SRS1650 MNG
SRS1650 MNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    DIODE ARRAY SCHOTTKY 50V TO263AB
SRS1650 MNG 数据手册
SRS1620 – SRS16100 Taiwan Semiconductor 16A, 20V - 100V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 16 A VRRM 20 - 100 V IFSM 150 A TJ MAX 125, 150 °C 2 Package TO-263AB (D PAK) Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-263AB (D PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.37g (approximately) 2 TO-263AB (D PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SRS 1620 SRS 1620 20 Reverse voltage, total rms value VR(RMS) 14 PARAMETER SYMBOL Marking code on the device SRS 1630 SRS 1630 30 SRS 1640 SRS 1640 40 SRS 1650 SRS 1650 50 SRS 1660 SRS 1660 60 21 28 35 42 SRS SRS UNIT 1690 16100 SRS SRS 1690 16100 90 100 V 63 70 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 16 A IFSM 150 A Storage temperature TSTG TJ -55 to +125 -55 to +150 -55 to +150 1 °C °C Version: L2103 SRS1620 – SRS16100 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 2 °C/W Junction-to-case thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS (1) Reverse current @ rated VR (2) per diode SRS1620 SRS1630 SRS1640 SRS1650 SRS1660 SRS1690 SRS16100 SRS1620 SRS1630 SRS1640 SRS1650 SRS1660 SRS1690 SRS16100 SRS1620 SRS1630 SRS1640 SRS1650 SRS1660 SRS1690 SRS16100 SRS1620 SRS1630 SRS1640 SRS1650 SRS1660 SRS1690 SRS16100 IF = 8A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.90 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) SRS16x PACKAGE 2 TO-263AB (D PAK) PACKING 800 / Tape & Reel Notes: 1. “x” defines voltage from 20V(SRS1620) to 100V(SRS16100) 2 Version: L2103 SRS1620 – SRS16100 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRS1650 - SRS16100 16 CAPACITANCE (pF) 12 SRS1620 - SRS1640 8 SRS1620 - SRS1640 SRS1650 - SRS1660 1000 SRS1690 - SRS16100 4 0 f=1.0MHz Vsig=50mVp-p 100 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=100°C 1 0.1 TJ=25°C 0.01 30 40 50 60 70 80 90 100 100 10 SRS1620 - SRS1640 10 UF1DLW 1 TJ=125°C TJ=25°C 0.1 SRS1690 - SRS16100 1 SRS1650 - SRS1660 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 200 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 20 8.3ms single half sine wave 150 100 50 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: L2103 1.2 SRS1620 – SRS16100 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: L2103 SRS1620 – SRS16100 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-263AB (D PAK) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: L2103 SRS1620 – SRS16100 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2103
SRS1650 MNG 价格&库存
很抱歉,暂时无法提供与“SRS1650 MNG”相匹配的价格&库存,您可以联系我们找货
