UG2DHR0G
UG2DHR0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE GEN PURP 200V 2A DO204AC
UG2DHR0G 数据手册
UG2D Taiwan Semiconductor 2A, 200V Ultra Fast Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ultra fast recovery time for high efficiency Excellent high temperature switching Glass passivated junction High surge current capability Low power loss, high efficiency RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 200 V IFSM 80 A TJ MAX 150 °C Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device UG2D UNIT UG2D Repetitive peak reverse voltage VRRM 200 V Reverse voltage, total rms value VR(RMS) 140 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 2 A IFSM 80 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: F2105 UG2D Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 60 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS IF = 2A, TJ = 25°C (1) Reverse current @ rated VR IF = 2A, TJ = 125°C (2) Junction capacitance Reverse recovery time TJ = 25°C SYMBOL VF IR TJ = 125°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A IF = 2.0A, VR = 30V, di/dt = 50A/µs, Irr = 10% IRM CJ TYP MAX UNIT - 0.95 V - 0.80 V - 5 µA - 200 µA 35 - pF - 15 ns 25 - ns trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING UG2D DO-204AC (DO-15) 3,500 / Tape & Reel UG2D A0G DO-204AC (DO-15) 1,500 / Ammo box UG2DH DO-204AC (DO-15) 3,500 / Tape & Reel UG2DHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. “H” means AEC-Q101 qualified 2 Version: F2105 UG2D Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 2 1 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=100°C 0.1 TJ=25°C 0.01 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C TJ=125°C TJ=100°C 1 0.1 TJ=25°C TJ=25°C 0.01 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 0.1 0.001 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.3 0.4 0.5 0.6 0.7 1 1.1 1.2 1.3 0.8 0.9 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 90 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 10 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 80 8.3ms single half sine wave 70 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 3 Version: F2105 1.2 UG2D Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: F2105 UG2D Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2105 UG2D Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: F2105
UG2DHR0G 价格&库存
很抱歉,暂时无法提供与“UG2DHR0G”相匹配的价格&库存,您可以联系我们找货
