MBRF30200CTHC0G
MBRF30200CTHC0G
    TAIWANSEMICONDUCTOR(台半)
    TO-220-3
    DIODE ARRAY SCHOTT 200V ITO220AB
MBRF30200CTHC0G 数据手册
MBRF3035CT – MBRF30200CT Taiwan Semiconductor 30A, 35V - 200V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 30 A VRRM 35 - 200 V IFSM 200 A TJ MAX 150 °C APPLICATIONS Package ITO-220AB Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF PARAMETER SYMBOL 3035 CT 3050 3060 CT CT CT 3090 30100 30150 30200 UNIT CT CT CT CT MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF 3035 3045 3050 3060 3090 30100 30150 30200 CT CT CT CT CT CT CT CT Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Peak repetitive reverse (1) surge current 3045 VRRM 35 45 50 60 90 100 150 200 V VR(RMS) 24 31 35 42 63 70 105 140 V IF 30 A IFSM 200 A IRRM 1.0 0.5 1 A Version: M2105 MBRF3035CT – MBRF30200CT Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF PARAMETER SYMBOL 3035 CT Peak repetitive forward current (Rated VR, Square wave, 20KHz) Critical rate of rise of off-state voltage Junction temperature Storage temperature Notes: 1. tp = 2.0μs, 1.0KHz 3045 3050 3060 CT CT CT 3090 30100 30150 30200 UNIT CT CT CT CT IFRM 30 A dv/dt 10,000 V/µs TJ TSTG -55 to +150 -55 to +150 °C °C THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 4 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MBRF3035CT MBRF3045CT MBRF3050CT MBRF3060CT MBRF3090CT MBRF30150CT Forward voltage per diode MBRF30200CT MBRF3045CT MBRF3050CT MBRF3090CT UNIT - 0.70 V - 0.75 V - 0.84 V - 0.95 V - 0.82 V - 0.90 V - 0.94 V - 1.05 V VF MBRF3035CT MBRF3060CT MAX IF = 15A,TJ = 25°C MBRF30100CT (1) TYP IF = 30A,TJ = 25°C MBRF30100CT MBRF30150CT MBRF30200CT 2 Version: M2105 MBRF3035CT – MBRF30200CT Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MBRF3035CT MBRF3045CT MBRF3050CT MBRF3060CT MBRF3090CT MBRF30150CT Forward voltage per diode MBRF30200CT MBRF3045CT MBRF3050CT MBRF3090CT UNIT - 0.60 V - 0.65 V - 0.70 V - 0.80 V - 0.73 V - 0.78 V - 0.82 V - 0.92 V - 200 µA - 20 mA - 15 mA - 10 mA VF MBRF3035CT MBRF3060CT MAX IF = 15A,TJ = 125°C MBRF30100CT (1) TYP IF = 30A,TJ = 125°C MBRF30100CT MBRF30150CT MBRF30200CT MBRF3035CT MBRF3045CT MBRF3050CT MBRF3060CT MBRF3090CT TJ = 25°C MBRF30100CT MBRF30150CT Reverse current @ rated VR per MBRF30200CT (2) MBRF3035CT diode IR MBRF3045CT MBRF3050CT MBRF3060CT MBRF3090CT TJ = 125°C MBRF30100CT MBRF30150CT MBRF30200CT Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MBRF30xCT ITO-220AB 50 / Tube MBRF30xCTH ITO-220AB 50 / Tube Notes: 1. “x” defines voltage from 35V(MBRF3035CT) to 200V(MBRF30200CT) 2. “H” means AEC-Q101 qualified 3 Version: M2105 MBRF3035CT – MBRF30200CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 MBRF3035CT-3045CT 30 MBRF3050CT-3060CT 25 CAPACITANCE (pF) 20 15 10 1000 100 MBRF3090CT-30200CT 5 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 TJ=75°C 0.1 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 100 10 MBRF3035CT-3045CT 1 MBRF3050CT-3060CT UF1DLW 10 TJ=125°C TJ=25°C 0.1 MBRF3090CT-30100CT 1 0.01 MBRF30150CT-30200CT 0.1 0.001 0.0 0.3 0.20.4 0.40.5 0.6 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs Pulse width 1% duty cycle 0.8 0.7 1.0 0.8 1.2 0.9 11.4 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 240 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) MBRF3035CT-3045CT MBRF3050CT-30200CT 0.01 100 Fig.4 Typical Forward Characteristics 1000 1 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 100 1 (A) AVERAGE FORWARD CURRENT (A) 35 200 8.3ms single half sine wave 160 120 80 40 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: M2105 1.2 MBRF3035CT – MBRF30200CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 5 Version: M2105 MBRF3035CT – MBRF30200CT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: M2105 MBRF3035CT – MBRF30200CT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: M2105
MBRF30200CTHC0G 价格&库存
很抱歉,暂时无法提供与“MBRF30200CTHC0G”相匹配的价格&库存,您可以联系我们找货
