TSF20U80C
Taiwan Semiconductor
20A, 80V Low VF Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
Compliant RoHS
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
A
VRRM
80
V
IFSM
100
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSF20U80C
UNIT
TSF20U80C
Repetitive peak reverse voltage
VRRM
80
V
Reverse voltage, total rms value
VR(RMS)
56
V
Isolation voltage from terminal to heatsink t = 1 min
VAC
1500
V
Forward current
Surge peak forward current, 8.3ms single half sinewave superimposed on rated load
(1)
Peak repetitive reverse surge current
Non-repetitive avalanche energy at L= 60mH, per
diode
Critical rate of rise of off-state voltage
IF
A
IFSM
100
A
IRRM
0.5
A
EAS
110
mJ
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: I2105
TSF20U80C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 5A, TJ = 25°C
Forward voltage per diode
IF = 10A, TJ = 25°C
(1)
IF = 5A, TJ = 125°C
VF
IF = 10A, TJ = 125°C
Reverse current @ rated VR per diode
(2)
TJ = 25°C
TJ = 125°C
IR
TYP
MAX
UNIT
0.52
V
0.67
0.77
V
0.48
V
0.62
0.70
V
600
µA
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
TSF20U80C
ITO-220AB
50 / Tube
2
Version: I2105
TSF20U80C
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
16
12
8
1000
100
4
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
CASE TEMPERATURE (°C)
100
TJ=150°C
TJ=125°C
1
TJ=100°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
10
100
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
1
REVERSE VOLTAGE (V)
90
100
100 10
10
1
TJ=150°C
UF1DLW
TJ=125°CTJ=125°C
TJ=25°C
0.1
1
TJ=25°C
0.01
TJ=100°C
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.0 0.30.2 0.40.4 0.50.6 0.60.8 0.71.0 0.81.2 0.91.4 1 1.6 1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
3
(A)
AVERAGE FORWARD CURRENT (A)
24
Version: I2105
1.2
TSF20U80C
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2105
TSF20U80C
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: I2105
很抱歉,暂时无法提供与“TSF20U80C C0G”相匹配的价格&库存,您可以联系我们找货
