TSF40U100C C0G
TSF40U100C C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY SCHOTT 100V ITO220AB
TSF40U100C C0G 数据手册
TSF40U100C Taiwan Semiconductor 40A, 100V Low VF Trench Schottky Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ high efficiency High forward surge capability Compliant RoHS Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 40 A VRRM 100 V IFSM 250 A TJ MAX 150 °C Package ITO-220AB Configuration Dual dies Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Mounting torque: 0.56 N⋅m maximum Polarity: As marked Weight: 1.70g (approximately) ITO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSF40U100C UNIT TSF40U100C Repetitive peak reverse voltage VRRM 100 V Reverse voltage, total rms value VR(RMS) 70 V IF 40 A IFSM 250 A dv/dt 10,000 V/µs Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Forward current Surge peak forward current, 8.3ms single half sinewave superimposed on rated load Critical rate of rise of off-state voltage 1 Version: B2105 TSF40U100C Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 3.5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 10A, TJ = 25°C Forward voltage per diode IF = 20A, TJ = 25°C (1) IF = 10A, TJ = 125°C VF IF = 20A, TJ = 125°C Reverse current @ rated VR per diode (2) TJ = 25°C TJ = 125°C IR TYP MAX UNIT 0.51 0.61 V 0.60 0.70 V 0.45 0.53 V 0.57 0.65 V - 500 µA - 100 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSF40U100C ITO-220AB 50 / Tube 2 Version: B2105 TSF40U100C Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 40 CAPACITANCE (pF) 30 20 1000 100 10 0 f=1.0MHz Vsig=50mVp-p 10 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) TJ=150°C 10 TJ=125°C 1 TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 100 10 REVERSE VOLTAGE (V) 90 100 100 10 10 1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=25°C 0.1 TJ=25°C 1 0.01 0.1 0.001 0.0 TJ=100°C Pulse width 300μs 1% duty cycle Pulse width 0.1 0.2 0.3 0.3 0.4 0.5 0.4 0.6 0.5 0.6 0.7 0.8 0.9 0.7 0.8 0.9 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 3 (A) AVERAGE FORWARD CURRENT (A) 50 Version: B2105 1.2 TSF40U100C Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AB MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: B2105 TSF40U100C Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2105
TSF40U100C C0G 价格&库存
很抱歉,暂时无法提供与“TSF40U100C C0G”相匹配的价格&库存,您可以联系我们找货
