UR4KB60-B C2G
UR4KB60-B C2G
    TAIWANSEMICONDUCTOR(台半)
    SIP4
    BRIDGE RECT 1PHASE 600V 4A D3K
UR4KB60-B C2G 数据手册
UR4KB60-B – UR4KB100-B Taiwan Semiconductor 4A, 600V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Ideal for printed circuit board High case dielectric strength High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply ● Adapters ● Lighting application PARAMETER VALUE UNIT IF 4 A VRRM 600 - 1000 V IFSM 135 A TJ MAX 150 °C Package D3K Configuration Quad MECHANICAL DATA ● ● ● ● ● ● ● Case: D3K Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Mounting torque: 0.80 N⋅m maximum Polarity: As marked Weight: 1.24g (approximately) D3K ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL UR4KB60-B UR4KB80-B UR4KB100-B UNIT Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Without heat sink, TC = 120°C Forward current With heat sink, TC = 138°C Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Rating for fusing (t
UR4KB60-B C2G 价格&库存
很抱歉,暂时无法提供与“UR4KB60-B C2G”相匹配的价格&库存,您可以联系我们找货
