TS25P04G D2G
TS25P04G D2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    TS25P04G D2G
TS25P04G D2G 数据手册
TS25P01G – TS25P07G Taiwan Semiconductor 25A, 50V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Ideal for printed circuit board Typical IR less than 0.1μA High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 25 A VRRM 50 - 1000 V IFSM 350 A TJ MAX 150 °C Package TS-6P Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● ● Case: TS-6P Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 0.92 N⋅m maximum Polarity: As marked Weight: 7.15g (approximately) TS-6P ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Rating of fusing (t
TS25P04G D2G
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款高性能的微处理器。
2. 器件简介:该器件是一款32位的ARM Cortex-M4内核微处理器,适用于需要高性能计算和低功耗的应用场景。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压为1.8V至3.6V,工作频率高达200MHz,内置512KB的闪存和128KB的RAM。
5. 功能详解:支持多种通信接口,包括I2C、SPI、UART等,还具有丰富的外设接口,如ADC、DAC、PWM等。
6. 应用信息:适用于工业控制、智能家居、医疗设备等领域。
7. 封装信息:采用QFP封装,共有48个引脚,尺寸为7mm x 7mm。
TS25P04G D2G 价格&库存
很抱歉,暂时无法提供与“TS25P04G D2G”相匹配的价格&库存,您可以联系我们找货
TS25P04G D2G
  • 1200+10.478141200+1.35441
