S1AL – S1ML
Taiwan Semiconductor
1A, 50V - 1000V Standard Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile package
Low power loss, high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
50 - 1000
V
IFSM
30
A
TJ MAX
175
°C
Package
Sub SMA
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: Sub SMA
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.019g (approximately)
Sub SMA
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL S1AL S1BL S1DL S1GL S1JL S1KL S1ML UNIT
Marking code on the device
1AL
1BL
1DL
1GL
1JL
1KL
1ML
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
1
Version: Q2108
S1AL – S1ML
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
(1)
RӨJL
25
°C/W
(2)
RӨJL
30
°C/W
RӨJA
85
°C/W
Junction-to-ambient thermal resistance
Notes:
1. Part number: S1AL - S1JL
2. Part number: S1KL - S1ML
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 1A, TJ = 25°C
(2)
Junction capacitance
Reverse recovery time
TJ = 25°C
SYMBOL
TYP
MAX
UNIT
VF
1.1
V
5
µA
50
µA
CJ
9
pF
trr
1800
ns
IR
TJ = 125°C
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S1xL
Sub SMA
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(S1AL) to 1000V(S1ML)
2
Version: Q2108
S1AL – S1ML
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
1
1
f=1.0MHz
Vsig=50mVp-p
0.1
25
55
85
115
145
175
0.1
1
LEAD TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
0.1
TJ=75°C
TJ=25°C
0.01
10
40
50
60
70
80
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10 10
UF1DLW
1
TJ=125°C
1
0.1
TJ=25°C
0.01
0.1
0.001
0.6 0.7 0.8 0.9
0.3
0.4
0.5
Pulse width 300μs
1% duty cycle
Pulse width
1.0 1.1 1.2 1.3 1.4
0.6
0.7
0.8
0.9
FORWARD VOLTAGE (V)
1.5
1
1.1
Fig.5 Maximum Non-Repetitive Forward Surge Current
40
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.3 Typical Reverse Characteristics
1
10
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: Q2108
1.2
S1AL – S1ML
PACKAGE OUTLINE DIMENSIONS
Sub SMA
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: Q2108
S1AL – S1ML
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: Q2108
很抱歉,暂时无法提供与“S1JLHMQG”相匹配的价格&库存,您可以联系我们找货
