MBRF1650 C0G
MBRF1650 C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-2
    DIODE SCHOTTKY 50V 16A ITO220AC
MBRF1650 C0G 数据手册
MBRF1635 – MBRF16150 Taiwan Semiconductor 16A, 35V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for over-voltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 16 A VRRM 35 - 150 V IFSM 150 A TJ MAX 150 °C Package ITO-220AC Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak revers voltage Reverse voltage total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Peak repetitive reverse surge (1) current Peak repetitive forward current (Rated VR, Square wave, 20KHz) Critical rate of rise of off-state voltage Junction temperature Storage temperature VRRM VR(RMS) MBRF MBRF MBRF MBRF MBRF 1635 1645 1650 1660 1690 MBRF MBRF MBRF MBRF MBRF 1635 1645 1650 1660 1690 35 45 50 60 90 24 31 35 42 63 MBRF 16100 MBRF 16100 100 70 MBRF UNIT 16150 MBRF 16150 150 V 105 V IF 16 A IFSM 150 A IRRM 1.0 0.5 A IFRM 32 A dv/dt 10,000 V/µs TJ -55 to +150 °C TSTG -55 to +150 °C Notes: 1. tp = 2.0μs, 1.0KHz 1 Version: K2105 MBRF1635 – MBRF16150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJC 3 °C/W Junction-to-case resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) MBRF1635 MBRF1645 MBRF1650 MBRF1660 MBRF1690 MBRF16100 MBRF16150 MBRF1635 MBRF1645 MBRF1650 MBRF1660 MBRF1690 MBRF16100 MBRF16150 MBRF1635 MBRF1645 MBRF1650 MBRF1660 MBRF1690 MBRF16100 MBRF16150 MBRF1635 MBRF1645 MBRF1650 MBRF1660 MBRF1690 MBRF16100 MBRF16150 SYMBOL IF = 16A, TJ = 25°C VF IF = 16A, TJ = 125°C TYP MAX UNIT - 0.63 V - 0.75 V - 0.85 V - 0.95 V - 0.57 V - 0.65 V - 0.75 V - 0.92 V - 500 µA 300 µA 100 µA - 15 mA - 10 mA - 7.5 mA - 5 mA TJ = 25°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MBRF16x ITO-220AC 50 / Tube MBRF16xH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 35V(MBRF1635) to 150V(MBRF16150) 2. “H” means AEC-Q101 qualified 2 Version: K2105 MBRF1635 – MBRF16150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 16 CAPACITANCE (pF) 12 8 100 4 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) MBRF1635-1645 MBRF1650-16150 1 TJ=125°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 100 90 100 100 10 1 10 UF1DLW TJ=125°C TJ=125°C 0.1 TJ=25°C TJ=25°C MBRF1635-1645 MBRF1650-1660 MBRF1690-16150 1 0.01 Pulse width 300μs Pulse width 1% duty cycle 0.001 0.1 0.4 0.3 0.5 0.60.6 0.7 0 0.3 0.1 0.2 0.4 0.5 0.7 0.80.80.9 0.9 1 1.1 11.2 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 180 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 (A) AVERAGE FORWARD CURRENT (A) 20 Version: K2105 1.2 MBRF1635 – MBRF16150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: K2105 MBRF1635 – MBRF16150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2105 MBRF1635 – MBRF16150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2105
MBRF1650 C0G 价格&库存
很抱歉,暂时无法提供与“MBRF1650 C0G”相匹配的价格&库存,您可以联系我们找货
