TS25PL05G D2G
TS25PL05G D2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1P 600V 25A TS-6P
TS25PL05G D2G 数据手册
TS25PL05G – TS25PL06G Taiwan Semiconductor 25A, 600V - 800V Low VF Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low Forward drop enhance the efficiency Oxide Planar chip junction High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 25 A VRRM 600 - 800 V IFSM 300 A TJ MAX 150 °C Package TS-6P Configuration Quad ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● ● Case: TS-6P Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Mounting torque: 0.80 N⋅m maximum Polarity: As marked Weight: 7.15g (approximately) TS-6P ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TS25PL05G TS25PL06G TS25PL05G TS25PL06G UNIT Repetitive peak reverse voltage VRRM 600 800 V Reverse voltage, total rms value VR(RMS) 420 560 V Forward current Surge peak forward current, single half t = 8.3ms sine-wave superimposed on rated load t = 1.0ms IF IFSM 25 A 300 A 900 A Rating of fusing (t
TS25PL05G D2G 价格&库存
很抱歉,暂时无法提供与“TS25PL05G D2G”相匹配的价格&库存,您可以联系我们找货
