SR315 A0G
SR315 A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-27(DO-201AA)
SR315 A0G 数据手册
SR302 – SR320 Taiwan Semiconductor 3A, 20V - 200V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage drop Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 3 A VRRM 20 - 200 V IFSM 80 A TJ MAX 125, 150 °C APPLICATIONS Package DO-201AD Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-201AD Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 1.10g (approximately) DO-201AD ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of offstate voltage Junction temperature Storage temperature SR 302 SR 302 SR 303 SR 303 SR 304 SR 304 SR 305 SR 305 SR 306 SR 306 SR 309 SR 309 SR 310 SR 310 SR 315 SR 315 SR 320 SR 320 VRRM 20 30 40 50 60 90 100 150 200 V VR(RMS) 14 21 28 35 42 63 70 105 140 V SYMBOL UNIT IF 3 A IFSM 80 A dv/dt 10,000 V/µs TJ -55 to +125 -55 to +150 TSTG -55 to +150 1 °C °C Version: J2105 SR302 – SR320 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 50 °C/W Junction-to-case thermal resistance RӨJC 15 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SR302 SR303 SR304 SR305 SR306 SR309 SR310 SR315 SR320 SR302 SR303 SR304 SR305 SR306 SR309 SR310 SR315 SR320 SR302 SR303 SR304 SR305 SR306 SR309 SR310 SR315 SR320 SR302 SR303 SR304 SR305 SR306 SR309 SR310 SR315 SR320 IF = 3A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 10 mA - 5 mA - - mA - - mA - - mA - 2 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms 2 Version: J2105 SR302 – SR320 Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR3x DO-201AD 1,250 / Tape & Reel SR3x A0G DO-201AD 500 / Ammo box SR3xH DO-201AD 1,250 / Tape & Reel SR3xHA0G DO-201AD 500 / Ammo box Notes: 1. "x" defines voltage from 20V (SR302) to 200V (SR320) 2. “H” means AEC-Q101 qualified 3 Version: J2105 SR302 – SR320 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SR305-SR320 SR302-SR304 3 CAPACITANCE (pF) 2 SR302-SR304 1 100 SR315-SR320 SR305-SR306 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=75°C SR302-SR304 SR305-SR320 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 1010 SR305-SR306 1 SR302-SR304 UF1DLW TJ=125°C TJ=25°C 10.1 SR315-SR320 SR309-SR310 0.01 0.1 0.001 0.20.3 0.3 0.40.4 0.5 0.5 Pulse width 300μs 1% 1% duty duty cycle cycle Pulse width 0.6 0.6 0.7 0.7 0.80.8 0.9 0.91 1.1 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 100 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 0.01 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 0.1 10 (A) AVERAGE FORWARD CURRENT (A) 4 8.3ms single half sine wave 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: J2105 1.2 SR302 – SR320 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 5 Version: J2105 SR302 – SR320 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-201AD MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: J2105 SR302 – SR320 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: J2105
SR315 A0G 价格&库存
很抱歉,暂时无法提供与“SR315 A0G”相匹配的价格&库存,您可以联系我们找货
SR315 A0G
  • 1+5.998901+0.77707
  • 10+3.7071510+0.48021
库存:34
