HER1601G – HER1608G
Taiwan Semiconductor
16A, 50V - 1000V High Efficient Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
High efficiency, low VF
High current capability
High surge current capability
Low power loss
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
50 - 1000
V
IFSM
125
A
TJ MAX
150
°C
Package
TO-220AB
Configuration
Dual dies
● DC to DC converters
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.82g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
HER HER HER HER HER HER HER HER
PARAMETER
SYMBOL
UNIT
1601G 1602G 1603G 1604G 1605G 1606G 1607G 1608G
Marking code on the
HER
HER
HER
HER
HER
HER
HER
HER
device
Repetitive peak
VRRM
50
100
200
300
400
600
800
1000
V
reverse voltage
Reverse voltage, total
VR(RMS)
35
70
140
210
280
420
560
700
V
rms value
Forward current
IF
16
A
Surge peak forward
current, 8.3ms single
half sine wave
IFSM
125
A
superimposed on rated
load
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
1
°C
Version: J2104
HER1601G – HER1608G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
HER1601G
HER1602G
HER1603G
HER1604G
HER1605G
HER1606G
HER1607G
HER1608G
Reverse current @ rated VR per diode
Junction capacitance per
diode
Reverse recovery time
(2)
IF = 8A, TJ = 25°C
TJ = 25°C
TJ = 125°C
HER1601G
HER1602G
HER1603G
HER1604G
1MHz, VR = 4.0V
HER1605G
HER1606G
HER1607G
HER1608G
HER1601G
HER1602G
HER1603G
HER1604G IF = 0.5A, IR = 1.0A,
HER1605G Irr = 0.25A
HER1606G
HER1607G
HER1608G
SYMBOL
VF
IR
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
10
µA
400
µA
80
pF
50
pF
50
ns
80
ns
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
HER16xG
TO-220AB
50 / Tube
HER16xGH
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 50V(HER1601G) to 1000V(HER1608G)
2. “H” means AEC-Q101 qualified
2
Version: J2104
HER1601G – HER1608G
CHARACTERISTICS CURVES
Fig.2 Typical Junction Capacitance
16
160
CAPACITANCE (pF)
12
8
4
HER1601G-1605G
120
HER1606G-1608G
80
40
50
75
100
125
f=1.0MHz
Vsig=50mVp-p
1
10
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
10
TJ=25°C
1
10
40
50
60
70
80
1000
Fig.4 Typical Forward Characteristics
1000
90
100
100 10
HER1601G-1604G
10
1
UF1DLW
HER1605G
TJ=125°C
TJ=25°C
0.1
1
HER1606G-1608G
0.01
0.1
0.001
0.4
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.6
0.8
1.0
0.4
0.5
0.6
1.2
0.7
1.4
0.8
1.6
0.9
1.8
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
100
100
REVERSE VOLTAGE (V)
(A)
AVERAGE FORWARD CURRENT (A)
Fig.1 Forward Current Derating Curve
125
8.3ms single half sine wave
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: J2104
1.2
HER1601G – HER1608G
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: J2104
HER1601G – HER1608G
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2104
HER1601G – HER1608G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2104
很抱歉,暂时无法提供与“HER1602G C0G”相匹配的价格&库存,您可以联系我们找货
