MBR20100CTHC0G
MBR20100CTHC0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    DIODE ARRAY SCHOTTKY 100V TO220
MBR20100CTHC0G 数据手册
MBR2035CT – MBR20200CT Taiwan Semiconductor 20A, 35V - 200V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters PARAMETER VALUE UNIT IF 20 A VRRM 35 - 200 V IFSM 150 A TJ MAX 150 °C Package TO-220AB Configuration Dual dies MECHANICAL DATA ● ● ● ● ● ● ● Case: TO-220AB Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.88g (approximately) TO-220AB ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER MBR 2035 CT MBR 2035 CT MBR 2045 CT MBR 2045 CT MBR 2050 CT MBR 2050 CT MBR 2060 CT MBR 2060 CT VRRM 35 45 50 60 90 100 150 200 V VR(RMS) 24 31 35 42 63 70 105 140 V SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Peak repetitive reverse (1) surge current Peak repetitive forward current (Rated VR, Square wave, 20KHz) MBR MBR MBR MBR 2090 20100 20150 20200 UNIT CT CT CT CT MBR MBR MBR MBR 2090 20100 20150 20200 CT CT CT CT IF 20 A IFSM 150 A IRRM 1 0.5 IFRM 20 1 A A Version: M2104 MBR2035CT – MBR20200CT Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) MBR MBR MBR MBR MBR MBR MBR MBR 2035 2045 2050 2060 2090 20100 20150 20200 UNIT PARAMETER SYMBOL CT CT CT CT CT CT CT CT Critical rate of rise of offdv/dt 10,000 V/μs state voltage Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C Notes: 1. tp = 2.0μs, 1.0KHz THERMAL PERFORMANCE PARAMETER Junction-to-case thermal resistance Junction-to-case thermal resistance SYMBOL TYP UNIT RӨJC 1 °C/W RӨJC 2 °C/W MBR2035CT MBR2045CT MBR2050CT MBR2060CT MBR2090CT MBR20100CT MBR20150CT MBR20200CT ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per (1) diode CONDITIONS MBR2035CT MBR2045CT MBR2050CT MBR2060CT MBR2090CT MBR20100CT MBR20150CT MBR20200CT MBR2035CT MBR2045CT MBR2050CT MBR2060CT MBR2090CT MBR20100CT MBR20150CT MBR20200CT MBR2035CT MBR2045CT MBR2050CT MBR2060CT MBR2090CT MBR20100CT MBR20150CT MBR20200CT MBR2035CT MBR2045CT MBR2050CT MBR2060CT MBR2090CT MBR20100CT MBR20150CT MBR20200CT SYMBOL TYP MAX UNIT - - V - 0.80 V - 0.85 V - 0.99 V - 0.84 V - 0.95 V - 1.23 V - 0.57 V - 0.70 V - 0.75 V - 0.87 V - 0.72 V - 0.85 V - 1.10 V IF = 10A, TJ = 25°C IF = 20A, TJ = 25°C VF IF = 10A, TJ = 125°C IF = 20A, TJ = 125°C 2 Version: M2104 MBR2035CT – MBR20200CT Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Reverse current @ rated VR (2) per diode CONDITIONS MBR2035CT MBR2045CT MBR2050CT MBR2060CT MBR2090CT MBR20100CT MBR20150CT MBR20200CT MBR2035CT MBR2045CT MBR2050CT MBR2060CT MBR2090CT MBR20100CT MBR20150CT MBR20200CT SYMBOL TJ = 25°C TYP MAX UNIT - 100 µA - 15 mA - 10 mA - 5 mA - 0.15 mA IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING MBR20xCT TO-220AB 50 / Tube MBR20xCTH TO-220AB 50 / Tube Notes: 1. “x” defines voltage from 35V(MBR2035CT) to 200V(MBR20200CT) 2. “H” means AEC-Q101 qualified 3 Version: M2104 MBR2035CT – MBR20200CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 20 CAPACITANCE (pF) 15 10 MBR2035CT - 2045CT 1000 MBR2050CT - 20200CT 5 f=1.0MHz Vsig=50mVp-p 100 0 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 1 TJ=75°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 100 10 10 1 TUF1DLW J=125°C TJ=125°C 0.1 0.01 0.1 0.001 0.0 TJ=25°C TJ=25°C 2035CT-2045CT 2050CT-2060CT 2090CT-20100CT 20150CT-20200CT 1 Pulse width 300μs 1% duty cycle Pulse width 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.2 0.4 0.6 0.4 0.5 0.6 0.8 0.7 1.0 0.8 1.2 0.9 1.4 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 180 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 1000 100 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics MBR2035CT-2045CT MBR2050CT-20100CT MBR20150CT-20200CT 10 (A) AVERAGE FORWARD CURRENT (A) 25 8.3ms single half sine wave 150 120 90 60 30 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: M2104 1.2 MBR2035CT – MBR20200CT Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Impedance TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.01 0.1 1 10 100 PULSE DURATION (s) 5 Version: M2104 MBR2035CT – MBR20200CT Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS TO-220AB MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: M2104 MBR2035CT – MBR20200CT Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: M2104
MBR20100CTHC0G
物料型号:MBR2035CT至MBR20200CT,涵盖从35V到200V的电压等级。
器件简介: - 这些肖特基二极管具有20A的正向电流能力,并且通过了AEC-Q101认证。 - 特点包括低功耗、高效率、过压保护的护环、高浪涌电流能力,符合RoHS标准和无卤素。
引脚分配:文档中提供了TO-220AB封装的引脚图,其中PIN1为阳极,PIN2和PIN3为阴极。
参数特性: - 包括正向电流(IF)、反向电压(VRRM)、浪涌正向电流(IFSM)、最大结温(TJMAX)等关键参数。 - 提供了不同型号的绝对最大额定值,如反向重复峰值电压(VRRM)、正向电流(IF)、浪涌峰值正向电流(IFSM)等。
功能详解: - 这些二极管适用于开关电源(SMPS)、适配器、DC-DC转换器等应用。 - 详细列出了电气规格,包括在不同条件下的正向电压、反向电流等。
应用信息:适用于开关电源、适配器、DC-DC转换器等。
封装信息:主要为TO-220AB封装,提供了详细的机械数据和订购信息。
MBR20100CTHC0G 价格&库存
很抱歉,暂时无法提供与“MBR20100CTHC0G”相匹配的价格&库存,您可以联系我们找货
