RYBS30M
Taiwan Semiconductor
3A, 1000V Fast Recovery Bridge Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
UL Recognized File # E-326854
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● Lighting application
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
1000
V
IFSM
90
A
TJ MAX
150
°C
Package
YBS
Configuration
Quad
MECHANICAL DATA
Case: YBS
Molding compound meets UL 94V-0 flammability rating
Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1 whisker test
Polarity: As marked
Weight: 0.220g (approximately)
YBS
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
RYBS30M
UNIT
RY30M
Marking code on the device
Repetitive peak reverse voltage
VRRM
1000
V
Reverse voltage, total rms value
VR(RMS)
700
V
IF
3
A
90
A
Forward current
Surge peak forward current
t = 8.3ms
single half sine-wave superimposed
t = 1.0ms
on rated load per diode
Rating for fusing (t
很抱歉,暂时无法提供与“RYBS30M M2G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.41280
- 200+1.32840
- 500+1.27440
- 1000+1.25280
