TS6K40 D3G
TS6K40 D3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 400V 6A TS4K
TS6K40 D3G 数据手册
TS6K40 – TS6K100 Taiwan Semiconductor 6A, 400V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Ideal for printed circuit board High surge current capability Typical IR less than 0.1µA UL Recognized File # E-326243 AEC-Q101 available RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 6 A VRRM 400 - 1000 V IFSM 150 A TJ MAX 150 °C Package TS4K Configuration Quad Switching mode power supply (SMPS) Adapters TV Monitor MECHANICAL DATA ● ● ● ● ● ● ● Case: TS4K Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Mounting torque: 8.17 in-lbs maximum Weight: 4.00g (approximately) + ~ ~ - TS4K ~ ~ + - ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TS6K40 TS6K60 TS6K80 TS6K100 UNIT TS6K40 TS6K60 TS6K80 TS6K100 Repetitive peak reverse voltage VRRM 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 280 420 560 700 V Forward current Surge peak forward current single half sine-wave superimposed on rated load per diode t = 8.3ms IF 6 A IFSM 150 A Rating of fusing ( t
TS6K40 D3G 价格&库存
很抱歉,暂时无法提供与“TS6K40 D3G”相匹配的价格&库存,您可以联系我们找货
