2M6.8ZHR0G
2M6.8ZHR0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE ZENER 6.8V 2W DO204AC
2M6.8ZHR0G 数据手册
2M6.8Z – 2M200Z Taiwan Semiconductor 2W, 6.8V - 200V Zener Diode FEATURES ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Typical IR less than 1µA RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 6.8 - 200 V Test current IZT 2.5 - 100 mA PD 2 W TJ MAX 175 °C APPLICATIONS Package DO-204AC (DO-15) Configuration Single die ● For general purpose regulation and protection applications MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Steady state power dissipation at T L = 75°C (1) Lead lengths .375", 9.55mm Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Operating junction temperature range Storage temperature range SYMBOL VALUE UNIT PD 2 W IFSM 15 A TJ -55 to +175 °C TSTG -55 to +175 °C Notes: 1. Mounted on Cu-Pad size 10mm x 10mm PCB 1 Version: N2105 2M6.8Z – 2M200Z Taiwan Semiconductor MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) Maximum Test Maximum Zener voltage Leakage current Zener current Zener Impedance Current Device(1) VZ @ IZT IZT ZZT@IZT ZZK@IZK V mA Ω Ω mA μA V mA 2M6.8Z 6.8 100 1.5 200 1.00 1000 5.5 246 2M11Z 11 45.5 4.0 700 0.25 1.0 8.4 166 2M12Z 12 41.5 4.5 700 0.25 1.0 9.1 152 2M13Z 13 38.5 5.0 700 0.25 0.5 9.9 138 2M14Z 14 35.7 5.5 700 0.25 0.5 10.6 130 2M15Z 15 33.4 7.0 700 0.25 0.5 11.4 122 2M16Z 16 31.2 8.0 700 0.25 0.5 12.2 114 2M17Z 17 29.4 9.0 750 0.25 0.5 13.0 107 2M18Z 18 27.8 10 750 0.25 0.5 13.7 100 2M19Z 19 26.3 11 750 0.25 0.5 14.4 95 2M20Z 20 25.0 11 750 0.25 0.5 15.2 90 2M22Z 22 22.8 12 750 0.25 0.5 16.7 82 2M24Z 24 20.8 13 750 0.25 0.5 18.2 76 2M27Z 27 18.5 18 750 0.25 0.5 20.6 68 2M30Z 30 16.6 20 1000 0.25 0.5 22.8 60 2M33Z 33 15.1 23 1000 0.25 0.5 25.1 55 2M36Z 36 13.9 25 1000 0.25 0.5 27.4 50 2M39Z 39 12.8 30 1000 0.25 0.5 29.7 47 2M43Z 43 11.6 35 1500 0.25 0.5 32.7 43 2M47Z 47 10.6 40 1500 0.25 0.5 35.8 39 2M51Z 51 9.8 48 1500 0.25 0.5 38.8 36 2M56Z 56 9.0 55 2000 0.25 0.5 42.6 32 2M62Z 62 8.1 60 2000 0.25 0.5 47.1 29 2M68Z 68 7.4 75 2000 0.25 0.5 51.7 27 2M75Z 75 6.7 90 2000 0.25 0.5 56.0 24 2M82Z 82 6.1 100 3000 0.25 0.5 62.2 22 2M91Z 91 5.5 125 3000 0.25 0.5 69.2 20 2M100Z 100 5.0 175 3000 0.25 0.5 76.0 18 2M110Z 110 4.5 250 4000 0.25 0.5 83.6 17 2M120Z 120 4.2 325 4500 0.25 0.5 91.2 15 2M130Z 130 3.8 400 5000 0.25 0.5 98.8 14 2M140Z 140 3.6 500 5500 0.25 0.5 106.4 13 2M150Z 150 3.3 575 6000 0.25 0.5 114.0 12 2M160Z 160 3.1 650 6500 0.25 0.5 121.6 11 2M170Z 170 2.9 675 7000 0.25 0.5 130.4 11 2M180Z 180 2.8 725 7000 0.25 0.5 136.8 10 2 IZK IR@VR IZM Version: N2105 2M6.8Z – 2M200Z Taiwan Semiconductor MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) Maximum Test Maximum Zener voltage Leakage current Zener current Zener Impedance Current Device(1) VZ @ IZT IZT ZZT@IZT ZZK@IZK IZK IR@VR IZM V mA Ω Ω mA μA V mA 2M190Z 190 2.6 825 8000 0.25 0.5 144.8 10 2M200Z 200 2.5 900 8000 0.25 0.5 152.0 9 Notes : 1. Tolerance - Standard Voltage tolerance = ±5%, tolerances may be considered as a special device 2. ZENER VOLTAGE(VZ) MEASUREMENT - Zener voltage guaranteed when measured at 0.375"(9.5mm) from the body under 40ms ±10ms current pulse and ambient temperature of 25°C 3. ZENER IMPEDANCE (ZZ) DERIVATION - The zener impedance is derived from 60 cycles AC voltage, which results when an current having an rms value eqal to 10% of the DC zener current (I ZT or IZK) is superimposed on IZT or IZK 4. MAXIMUM ZENER CURRENT (IZM) NON-REPETITIVE - The rating listed in the electrical characteristics table is maximum peak non - repetitive reverse surge current of 1/2 sine wave of 1/120 second duration or equivalent square wave, superimposed on the test current IZT, per JEDEC standard. ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 2MxZ DO-204AC (DO-15) 3,500 / Tape & Reel 2MxZ A0G DO-204AC (DO-15) 1,500 / Ammo box 2MxZH DO-204AC (DO-15) 3,500 / Tape & Reel 2MxZHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. "x" defines voltage from 6.8V (2M6.8Z) to 200V (2M200Z) 2. “H” means AEC-Q101 qualified 3 Version: N2105 2M6.8Z – 2M200Z Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Maximum Surge Power Fig.2 Typical Reverse Leakage IR, REVERSE LEAKAGE (uAdc) @VR AS SPECIFIED IN ELEC.CHAR, TABLE A Ppk, PEAKSURGE POWER (W) 1000 100 10 1 0.1 1 10 1 0.1 Range 0.01 0.001 0.0001 100 1 10 Fig.4 Unit 13V - 200V 8 7 6 5 4 3 Range 1 0 -1 -2 -3 -4 VZ @ IZT -5 4 5 6 7 8 9 10 11 12 Vz, TEMPERATURE COEFFICIENT (mC/℃) @IZT Vz, TEMPERATURE COEFFICIENT (mC/℃) @IZT Fig.3 Unit 6.8V - 12V 3 1000 NORMAL Vz (VOLTS) PW, PULSE WIDTH (ms) 2 100 Vz, ZENER VOLTAGE @IZT (VOLTS) 8 7 6 5 4 3 2 1 0 -1 -2 -3 -4 -5 Range VZ @ IZT 0 20 40 60 80 100 120 140 160 180 200 Vz, ZENER VOLTAGE @IZT (VOLTS) 4 Version: N2105 2M6.8Z – 2M200Z Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 VZ 6.8V - 10V Fig.6 VZ 11V - 91V 100 IZ, ZENER CURRENT (mA) IZ, ZENER CURRENT (mA) 100 10 1 0.1 10 1 0.1 0 1 2 3 4 5 6 7 8 9 10 0 10 VZ, ZENER VOLTAGE (VOLTS) JL, JUNCTION-LEAD THERMAL RESISTANCE(℃/W) IZ, ZENER CURRENT (mA) 10 1 0.1 140 160 40 50 60 70 80 90 100 Fig.8 Typical Thermal Resistance 100 120 30 VZ, ZENER VOLTAGE (VOLTS) Fig.7 VZ 100V - 200V 100 20 180 200 80 70 60 50 40 30 20 10 0 0 0.125 0.25 0.375 0.5 0.625 0.75 0.875 L, LEAD LENGTH TO HEAT SINK (INCH) VZ, ZENER VOLTAGE (VOLTS) 5 Version: N2105 1 2M6.8Z – 2M200Z Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) ΘJL(t,D)TRANSIENT THERMAL RESISTANCE JUNCTION-TO-LEAD(℃/W) Fig.9 Typical Thermal Response 100 D=0.5 D=0.2 D=0.05 D=0.1 10 NOTE BELOW 0.1 SECOND, THERMAL RESPONSE CURVE IS APPLICABLE TO ANY LEAD LENGTH(L) 1 D=0.01 D=0.02 SINGLE PULSE △TJL=ΘJL(1)PPK REPETITIVE PULSE △TJL=ΘJL(1,D)PPK D=0 0.1 0.01 0.1 1 10 100 1000 PW, PULSE WIDTH (ms) 6 Version: N2105 2M6.8Z – 2M200Z Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 7 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: N2105 2M6.8Z – 2M200Z Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8 Version: N2105
2M6.8ZHR0G 价格&库存
很抱歉,暂时无法提供与“2M6.8ZHR0G”相匹配的价格&库存,您可以联系我们找货
