TST10H100CW – TST10H200CW
Taiwan Semiconductor
10A, 100V - 200V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ High efficiency
High forward surge capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
10
A
VRRM
100 - 200
V
IFSM
100
A
TJ MAX
150
°C
Package
TO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.88g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Critical rate of rise of off-state voltage
TST10H TST10H TST10H TST10H
UNIT
100CW 120CW 150CW 200CW
100CW
120CW
150CW
200CW
100
120
150
200
V
70
84
105
140
V
IF
10
A
IFSM
100
A
dv/dt
10,000
V/μs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: B2104
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3.2
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TST10H100CW
TST10H120CW
TST10H150CW
Forward voltage per
(1)
diode
TST10H200CW
VF
TST10H100CW
TST10H120CW
TST10H150CW
Reverse current @ rated
(2)
VR per diode
IF = 5A, TJ = 25°C
IF = 5A, TJ = 125°C
TST10H200CW
TST10H100CW
TST10H120CW
TJ = 25°C
TST10H150CW
TST10H200CW
TST10H100CW
TST10H120CW
TJ = 125°C
TST10H150CW
TST10H200CW
TYP
MAX
UNIT
0.62
0.70
V
0.69
0.79
V
0.78
0.88
V
0.81
0.91
V
0.55
0.63
V
0.58
0.66
V
0.64
0.72
V
0.67
0.75
V
100
µA
15
mA
10
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TST10HxCW
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 100V(TST10H100CW) to 200V(TST10H200CW)
2
Version: B2104
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
10
5
75
100
125
TST10H120CW
100
TST10H150CW
f=1.0MHz
Vsig=50mVp-p
10
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TST10H100CW
TJ=150°C
TJ=125°C
TJ=100°C
0.1
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90
100
100 10
10
1
TJ=150°C
1
TJ=125°C
TJ=100°C
0.01
0.001
TJ=25°C
40
50
60
70
80
90
TJ=25°C
TJ=100°C
1
TJ=25°C
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
TST10H120CW
10
TJ=150°C
FORWARD VOLTAGE (V)
100
0.0001
UF1DLW
0.1
Fig.5 Typical Reverse Characteristics
0.1
TST10H100CW
TJ=125°C
TJ=125°C
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
100
Fig.4 Typical Forward Characteristics
100
1
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
TST10H200CW
(A)
25
TST10H100CW
1000
100
100 10
TST10H120CW
10
1
0.1
1
0.01
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
(A)
AVERAGE FORWARD CURRENT (A)
15
TJ=100°C
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
FORWARD VOLTAGE (V)
3
Version: B2104
Fig.8 Typical Forward Characteristics
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90
100
100 10
TST10H150CW
10
1
0.1
TJ=150°C
0.1
TJ=100°C
0.001
TJ=25°C
0.00001
10
40
50
60
70
80
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
0.1
0.001
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
1.2
Fig.10 Typical Forward Characteristics
TJ=125°C
0.0001
TJ=25°C
FORWARD VOLTAGE (V)
10
0.01
TJ=25°C
TJ=100°C
0.01
Fig.9 Typical Reverse Characteristics
1
TJ=150°C
TJ=125°C
TJ=125°C
1
TST10H200CW
UF1DLW
90 100
100 10
TST10H200CW
10
1
0.1
1
0.01
UF1DLW
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
TJ=100°C
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
FORWARD VOLTAGE (V)
4
(A)
TST10H150CW
(A)
10
Fig.7 Typical Reverse Characteristics
Version: B2104
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: B2104
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: B2104
很抱歉,暂时无法提供与“TST10H100CW C0G”相匹配的价格&库存,您可以联系我们找货
