SR302 – SR320
Taiwan Semiconductor
3A, 20V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low forward voltage drop
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
20 - 200
V
IFSM
80
A
TJ MAX
125, 150
°C
APPLICATIONS
Package
DO-201AD
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: DO-201AD
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 1.10g (approximately)
DO-201AD
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total
rms value
Forward current
Surge peak forward
current, 8.3ms single half
sine wave superimposed
on rated load
Critical rate of rise of offstate voltage
Junction temperature
Storage temperature
SR
302
SR
302
SR
303
SR
303
SR
304
SR
304
SR
305
SR
305
SR
306
SR
306
SR
309
SR
309
SR
310
SR
310
SR
315
SR
315
SR
320
SR
320
VRRM
40
50
60
90
100
150
200
V
VR(RMS)
14
21
28
35
42
63
70
105
140
V
SYMBOL
UNIT
IF
3
A
IFSM
80
A
dv/dt
10,000
V/µs
TJ
-55 to +125
-55 to +150
TSTG
-55 to +150
1
°C
°C
Version: J2105
SR302 – SR320
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
50
°C/W
Junction-to-case thermal resistance
RӨJC
15
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SR302
SR303
SR304
SR305
SR306
SR309
SR310
SR315
SR320
SR302
SR303
SR304
SR305
SR306
SR309
SR310
SR315
SR320
SR302
SR303
SR304
SR305
SR306
SR309
SR310
SR315
SR320
SR302
SR303
SR304
SR305
SR306
SR309
SR310
SR315
SR320
IF = 3A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.85
V
0.95
V
500
µA
100
µA
10
mA
5
mA
mA
mA
mA
2
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
2
Version: J2105
SR302 – SR320
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SR3x
DO-201AD
1,250 / Tape & Reel
SR3x A0G
DO-201AD
500 / Ammo box
SR3xH
DO-201AD
1,250 / Tape & Reel
SR3xHA0G
DO-201AD
500 / Ammo box
Notes:
1. "x" defines voltage from 20V (SR302) to 200V (SR320)
2. “H” means AEC-Q101 qualified
3
Version: J2105
SR302 – SR320
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SR305-SR320
SR302-SR304
3
CAPACITANCE (pF)
2
SR302-SR304
1
100
SR315-SR320
SR305-SR306
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
1
TJ=75°C
SR302-SR304
SR305-SR320
TJ=25°C
0.001
10
40
50
60
70
80
90
100
1010
SR305-SR306
1
SR302-SR304
UF1DLW
TJ=125°C
TJ=25°C
10.1
SR315-SR320
SR309-SR310
0.01
0.1
0.001
0.20.3 0.3 0.40.4 0.5
0.5
Pulse width 300μs
1%
1% duty
duty cycle
cycle
Pulse width
0.6
0.6
0.7
0.7 0.80.8 0.9 0.91
1.1
1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
100
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
10
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
0.1
10
(A)
AVERAGE FORWARD CURRENT (A)
4
8.3ms single half sine wave
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: J2105
1.2
SR302 – SR320
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: J2105
SR302 – SR320
PACKAGE OUTLINE DIMENSIONS
DO-201AD
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2105
SR302 – SR320
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: J2105
很抱歉,暂时无法提供与“SR310 B0G”相匹配的价格&库存,您可以联系我们找货
