TST20U45CW – TST20U60CW
Taiwan Semiconductor
20A, 45V - 60V Low VF Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ High efficiency
High forward surge capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
A
VRRM
45 - 60
V
IFSM
200
A
TJ MAX
150
°C
APPLICATIONS
Package
TO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 1.88g (approximately)
TO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TST20U45CW
TST20U60CW
TST20U45CW
TST20U60CW
UNIT
Repetitive peak reverse voltage
VRRM
45
60
V
Reverse voltage, total rms value
VR(RMS)
31
42
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Critical rate of rise of off-state voltage
IF
A
IFSM
200
A
dv/dt
10,000
V/μs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: C2104
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
TST20U45CW
TST20U60CW
TST20U45CW
Forward voltage per
(1)
diode
TST20U60CW
TST20U45CW
TST20U60CW
TST20U45CW
TST20U60CW
Reverse current @ rated VR per diode
(2)
SYMBOL
IF = 10A, TJ = 25°C
IF = 20A, TJ = 25°C
VF
IF = 10A, TJ = 125°C
IF = 20A, TJ = 125°C
TJ = 25°C
TJ = 125°C
IR
TYP
MAX
UNIT
0.45
0.51
V
0.48
0.54
V
0.53
0.59
V
0.57
0.63
V
0.38
0.44
V
0.42
0.48
V
0.50
0.56
V
0.55
0.61
V
500
µA
100
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TST20UxCW
TO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 45V(TST20U45CW) to 60V(TST20U60CW)
2
Version: C2104
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
TST20U45CW
CAPACITANCE (pF)
15
10
1000
TST20U60CW
5
f=1.0MHz
Vsig=50mVp-p
75
100
125
100
0.10
150
1.00
CASE TEMPERATURE (°C)
1000
TST20U45CW
TJ=150°C
10
TJ=125°C
1
TJ=100°C
0.1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
100 10
10
TST20U45CW
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=125°C
1
TJ=25°C
0.01
0.1
0.001
0.0
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.3
0.4
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TST20U60CW
TJ=150°C
10
TJ=125°C
TJ=100°C
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
0.3
0.4
0.6
0.7
0.8
0.5
0.9
0.6
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
1000
0.01
0.2
0.5
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
1
TJ=25°C
TJ=100°C
0.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
100
100.00
Fig.4 Typical Forward Characteristics
Fig.3 Typical Reverse Characteristics
100
10.00
REVERSE VOLTAGE (V)
(A)
25
100
100 10
10
TST20U60CW
UF1DLW
1
TJ=150°C
TJ=125°C
TJ=125°C
TJ=100°C
1
TJ=25°C
0.01
Pulse width 300μs
1% duty cycle
0.1
0.0
0.001
0.1
0.3
TJ=25°C
0.1
(A)
AVERAGE FORWARD CURRENT (A)
25
0.2
0.4
0.3
0.5
0.4
0.6
0.5
0.7
0.6
0.8
Pulse width
0.7 0.8
0.9
1
FORWARD VOLTAGE (V)
3
Version: C2104
Fig.7 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
250
8.3ms single half sine wave
200
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: C2104
PACKAGE OUTLINE DIMENSIONS
TO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: C2104
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C2104
很抱歉,暂时无法提供与“TST20U60CW C0G”相匹配的价格&库存,您可以联系我们找货
