UF1B R0G
UF1B R0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE GEN PURP 100V 1A DO204AL
UF1B R0G 数据手册
UF1A – UF1M Taiwan Semiconductor 1A, 50V - 1000V High Efficient Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction Excellent high temperature switching Soft recovery characteristics RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application PARAMETER VALUE UNIT IF 1 A VRRM 50 - 1000 V IFSM 30 A TJ MAX 150 °C Package DO-204AL (DO-41) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL UF1A UF1B UF1D UF1G UF1J UF1K UF1M UNIT Marking code on the device UF1A UF1B UF1D UF1G UF1J UF1K UF1M Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: G2104 UF1A – UF1M Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 15 °C/W Junction-to-ambient thermal resistance RӨJA 60 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) CONDITIONS UF1A UF1B UF1D UF1G IF = 1A, TJ = 25°C UF1J UF1K UF1M TJ = 25°C TJ = 125°C Junction capacitance Reverse recovery time 1MHz, VR = 4.0V UF1A UF1B UF1D I = 0.5A, IR = 1.0A, UF1G F I = 0.25A UF1J rr UF1K UF1M SYMBOL TYP MAX UNIT - 1.0 V - 1.7 V - 5 µA - 150 µA 17 - pF - 50 ns - 75 ns VF IR CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING UF1x DO-204AL (DO-41) 5,000 / Tape & Reel UF1x A0G DO-204AL (DO-41) 3,000 / Ammo box UF1xH DO-204AL (DO-41) 5,000 / Tape & Reel UF1xHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 50V (UF1A) to 1000V (UF1M) 2. “H” means AEC-Q101 qualified 2 Version: G2104 UF1A – UF1M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) 1 0 25 50 75 100 125 UF1J-UF1M 10 UF1A-UF1G f=1.0MHz Vsig=50mVp-p 1 150 0.1 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 1 0.1 TJ=25°C TJ=100°C 0.01 10 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 1000 90 100 10 10 1 UF1A-UF1G UF1DLW TJ=125°C TJ=25°C 1 0.1 UF1J-UF1M 0.01 0.1 0.001 0.5 0.7 0.9 1.1 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 1.3 0.7 1.5 0.8 1.7 0.9 1.9 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 35 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics UF1A-UF1G UF1J-UF1M 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 2 30 8.3ms single half sine wave 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: G2104 1.2 UF1A – UF1M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: G2104 UF1A – UF1M Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: G2104 UF1A – UF1M Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: G2104
UF1B R0G 价格&库存
很抱歉,暂时无法提供与“UF1B R0G”相匹配的价格&库存,您可以联系我们找货
