SS36LHRUG
SS36LHRUG
    TAIWANSEMICONDUCTOR(台湾半导体)
    Sub SMA
SS36LHRUG 数据手册
SS34L – SS310L Taiwan Semiconductor 3A, 40V - 100V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 3 A VRRM 40 - 100 V IFSM 80 A TJ MAX 125, 150 °C Package Sub SMA Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● Case: Sub SMA Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 0.019g (approximately) Sub SMA ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SS34L SS36L SS310L 34L 36L 310L UNIT Repetitive peak reverse voltage VRRM 40 60 100 V Reverse voltage, total rms value VR(RMS) 28 42 70 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Critical rate of rise of off-state voltage IF 3 A IFSM 80 A dV/dt 10,000 V/μs Junction temperature TJ Storage temperature TSTG - 55 to +125 - 55 to +150 - 55 to +150 1 °C °C Version: C2103 SS34L – SS310L Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-case thermal resistance RӨJC 30 °C/W Junction-to-ambient thermal resistance RӨJA 60 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL SS34L Forward voltage (1) SS36L SS310L SS34L SS36L SS310L Reverse current @ rated VR (2) IF = 3A, TJ = 25°C TJ = 25°C IR SS34L SS36L VF TJ = 125°C SS310L TYP MAX UNIT - 0.50 V - 0.75 V - 0.85 V - 500 µA - 100 µA - 60 mA - 10 mA - 5 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SS3xL Sub SMA 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 40V(SS34L) to 100V(SS310L) 2 Version: C2103 SS34L – SS310L Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SS36L - SS310L SS34L - SS36L 3 CAPACITANCE (pF) 2 SS34L 1 100 SS310L 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 10 1 SS34L SS36L - SS310L 0.01 0.001 TJ=25°C 0.0001 20 30 40 50 60 70 80 90 100 1010 1 SS34L SS36L UF1DLW SS310L TJ=125°C T =125°C J TJ=25°C 1 0.1 TJ=25°C 0.01 0.1 0.001 0.0 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.2 0.4 0.5 0.4 0.6 0.6 0.7 0.8 0.8 0.9 1.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 100 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 0.1 10 (A) AVERAGE FORWARD CURRENT (A) 4 8.3ms single half sine wave 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: C2103 1.2 SS34L – SS310L Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS Sub SMA SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: C2103 SS34L – SS310L Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2103
SS36LHRUG
物料型号:SS34L, SS36L, SS310L
器件简介: - 低功耗,高效率 - 适合自动化放置 - 防护环用于过电压保护 - 高浪涌电流能力 - 符合RoHS标准和无卤素标准
应用信息: - 开关电源(SMPS) - 适配器 - DC-DC转换器
封装信息: - 封装类型:Sub SMA - 符合UL 94V-0阻燃等级 - 引脚:镀锡,可焊性符合J-STD-002 - 符合JESD 201 1A级晶须测试 - 极性:通过阴极带指示
参数特性: - 正向电流(IF):3A - 反向电压(VRRM):40V - 100V - 峰值正向浪涌电流(IFSM):80A - 最大结温(TJMAX):125°C 或 150°C - 封装:Sub SMA - 配置:单芯片
功能详解: - 热性能:结到外壳热阻(ReJc)30°C/W,结到环境热阻(ReJA)60°C/W - 电气规格:正向电压(VF)在3A电流和25°C条件下分别为0.50V, 0.75V, 0.85V - 反向电流(IR)在额定反向电压下分别为500μA和100μA
订购信息: - 订购代码:SS3xL,其中“x”定义电压从40V(SS34L)到100V(SS310L) - 包装:10,000/卷带
特性曲线: - 正向电流降额曲线 - 典型结电容 - 典型反向特性 - 典型正向特性 - 最大非重复正向浪涌电流
封装尺寸: - 提供了Sub SMA封装的详细尺寸和建议的焊盘布局。
标记图: - 标记代码、绿色化合物、日期代码和工厂代码的说明。
注意事项: - 产品规格如有变更,恕不另行通知。 - 购买者对TSC产品的选用、选择和使用负全部责任。 - 产品不适用于医疗、救生或维持生命等应用。
SS36LHRUG 价格&库存
很抱歉,暂时无法提供与“SS36LHRUG”相匹配的价格&库存,您可以联系我们找货
