1N5400G – 1N5408G
Taiwan Semiconductor
3A, 50V - 1000V Standard Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High current capability, Low VF
High reliability
High surge current capability
Low power loss, high efficiency
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
50 - 1000
V
IFSM
125
A
TJ MAX
150
°C
Package
DO-201AD
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● General purpose
MECHANICAL DATA
Case: DO-201AD
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 1.20g (approximately)
DO-201AD
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the
device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward
current, 8.3ms single half
sine wave superimposed
on rated load
Junction temperature
Storage temperature
SYMBOL
1N
1N
1N
1N
1N
1N
1N
UNIT
5400G 5401G 5402G 5404G 5406G 5407G 5408G
1N
1N
1N
1N
1N
1N
1N
VRRM
50
100
200
400
600
800
1000
V
VR(RMS)
35
70
140
280
420
560
700
V
IF
3
A
IFSM
125
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
1
Version: K2105
1N5400G – 1N5408G
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
45
°C/W
Junction-to-case thermal resistance
RӨJC
15
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
(1)
Reverse current @ rated VR
(2)
CONDITIONS
1N5400G
1N5401G
1N5402G
1N5404G
I = 3A, TJ = 25°C
1N5405G F
1N5406G
1N5407G
1N5408G
TJ = 25°C
Junction capacitance
TJ = 125°C
1MHz, VR = 4.0V
SYMBOL
TYP
MAX
UNIT
1.1
V
1.0
V
5
µA
100
µA
25
pF
VF
IR
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
1N54xG
DO-201AD
1,250 / Tape & Reel
1N54xG A0G
DO-201AD
500 / Ammo box
1N54xGH
DO-201AD
1,250 / Tape & Reel
1N54xGHA0G
DO-201AD
500 / Ammo box
Notes:
1. "x" defines voltage from 50V (1N5400G) to 1000V (1N5408G)
2. “H” means AEC-Q101 qualified
2
Version: K2105
1N5400G – 1N5408G
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
3
CAPACITANCE (pF)
2
1
10
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
1
150
10
ANBIENT TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
0.1
TJ=75°C
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
1010
UF1DLW
1N5402G-1N5408G
1
TJ=125°C
TJ=25°C
10.1
1N5400G-1N5401G
0.01
0.1
0.001
0.60.3 0.7
0.4 0.8
0.5
Pulse
Pulse width
width 300μs
300μs
1% duty cycle
Pulse width
0.9
0.6
1
0.7
1.1
0.8
1.2
0.9
11.3
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
150
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
1
100
(A)
AVERAGE FORWARD CURRENT (A)
4
8.3ms single half sine wave
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2105
1.2
1N5400G – 1N5408G
PACKAGE OUTLINE DIMENSIONS
DO-201AD
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2105
1N5400G – 1N5408G
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: K2105
很抱歉,暂时无法提供与“1N5408GHA0G”相匹配的价格&库存,您可以联系我们找货
