MBRS20H100CT – MBRS20H200CT
Taiwan Semiconductor
20A, 100V - 200V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
A
VRRM
100 - 200
V
IFSM
150
A
TJ MAX
175
APPLICATIONS
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.40g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
MBRS
20H100CT
MBRS
20H100CT
100
Reverse voltage, total rms value
VR(RMS)
70
PARAMETER
SYMBOL
Marking code on the device
MBRS
20H150CT
MBRS
20H150CT
150
105
MBRS
UNIT
20H200CT
MBRS
20H200CT
200
V
140
V
Forward current
Surge peak forward current, 8.3ms single half
sine wave superimposed on rated load
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
(1)
Peak repetitive reverse surge current
IF
A
IFSM
150
A
IFRM
A
IRRM
Critical rate of rise of off-state voltage
dv/dt
10,000
V/µs
Junction temperature
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
1
0.5
A
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: J2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
1.5
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per
(1)
diode
CONDITIONS
MBRS20H100CT
MBRS20H150CT
MBRS20H200CT
MBRS20H100CT
MBRS20H150CT
MBRS20H200CT
MBRS20H100CT
MBRS20H150CT
MBRS20H200CT
MBRS20H100CT
MBRS20H150CT
MBRS20H200CT
Reverse current @ rated VR per diode
(2)
SYMBOL
TYP
MAX
UNIT
0.85
V
0.88
V
0.95
V
0.97
V
IF = 10A, TJ = 125°C
0.75
V
IF = 20A, TJ = 125°C
0.85
V
5
µA
2
mA
IF = 10A, TJ = 25°C
IF = 20A, TJ = 25°C
VF
TJ = 25°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
MBRS20HxCT
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 100V(MBRS20H100CT) to 200V(MBRS20H200CT)
2
Version: J2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
15
10
1000
100
5
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
175
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
1
TJ=125°C
0.1
TJ=75°C
0.001
TJ=25°C
0.0001
40
50
60
70
80
90
100
100 10
10
UF1DLW
1
TJ=125°C
TJ=125°C
0.1
TJ=25°C
TJ=25°C
1
0.01
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
10
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
0.01
10
(A)
AVERAGE FORWARD CURRENT (A)
25
8.3ms single half sine wave
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: J2103
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: J2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2103
很抱歉,暂时无法提供与“MBRS20H100CT MNG”相匹配的价格&库存,您可以联系我们找货
