GBU401 D2G
GBU401 D2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    SIP4
    BRIDGE RECT 1PHASE 50V 4A GBU
GBU401 D2G 数据手册
GBU401 – GBU407 Taiwan Semiconductor 4A, 50V - 1000V Standard Bridge Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for printed circuit board High case dielectric strength of 1500VRMS High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 4 A VRRM 50 - 1000 V IFSM 150 A TJ MAX 150 °C Package GBU Configuration Quad ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● Case: GBU Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: As marked Weight: 4.00g (approximately) GBU ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM GBU 401 GBU 401 50 Reverse voltage, total rms value VR(RMS) 35 PARAMETER SYMBOL Marking code on the device Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Surge peak forward current, 1.0ms single half sine-wave superimposed on rated load IF TJ = 25°C GBU 402 GBU 402 100 GBU 403 GBU 403 200 GBU 404 GBU 404 400 GBU 405 GBU 405 600 GBU 406 GBU 406 800 70 140 280 420 560 GBU UNIT 407 GBU 407 1000 V 700 V 4 A 150 A 80 A 280 A 260 A IFSM TJ = 125°C TJ = 25°C IFSM TJ = 125°C 1 Version: M2103 GBU401 – GBU407 Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL GBU 401 GBU 402 GBU 403 GBU 404 GBU 405 GBU 406 GBU UNIT 407 Rating for fusing (t
GBU401 D2G 价格&库存
很抱歉,暂时无法提供与“GBU401 D2G”相匹配的价格&库存,您可以联系我们找货
