1SMB5930HM4G
1SMB5930HM4G
    TAIWANSEMICONDUCTOR(台半)
    DO214AA
    DIODE ZENER 16V 3W DO214AA
1SMB5930HM4G 数据手册
1SMB5926 – 1SMB5956 Taiwan Semiconductor 3W, 11V - 200V Surface Mount Zener Diode FEATURES ● ● ● ● ● ● KEY PARAMETERS Ideal for automated placement Glass passivated chip junction Low inductance Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 11 - 200 V Test current IZT 1.9 - 34.1 mA Ptot 3 W TJ MAX 150 °C APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter Package DO-214AA (SMB) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.100g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT 3 W 40 mW/°C 550 mW 4.4 mW/°C DC power dissipation at TL=75°C, measure at zero lead length (Note 1) derate above 75°C PD DC power dissipation at TA=25°C Derate above 25°C PD Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 25 °C/W Junction-to-ambient thermal resistance RӨJA 226 °C/W Note: 1. Mounted on Cu-Pad size 5mm x 5mm on PCB THERMAL PERFORMANCE PARAMETER 1 Version: M2102 1SMB5926 – 1SMB5956 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Device (Note 1) Device Marking Code Nominal Zener Voltage Test current Vz@IZT IZT ZZT @ IZT V Nom (Note 2) mA Ω Min Zener Impedance (Note 3) ZZK@IZK Ω mA Leakage Current Maximum DC Zener Current IR@VR IZM μA V mA(DC) Max 1SMB5926 926B 10.45 11 11.55 34.1 5.5 550 0.25 1 8.4 136 1SMB5927 927B 11.40 12 12.60 31.2 6.5 550 0.25 1 9.1 125 1SMB5928 928B 12.35 13 13.65 28.8 7.0 550 0.25 1 9.9 115 1SMB5929 929B 14.25 15 15.75 25.0 9.0 600 0.25 1 11.4 100 1SMB5930 930B 15.20 16 16.80 23.4 10.0 600 0.25 1 12.2 94 1SMB5931 931B 17.10 18 18.90 20.8 12.0 650 0.25 1 13.7 83 1SMB5932 932B 19.00 20 21.00 18.7 14.0 650 0.25 1 15.2 75 1SMB5933 933B 20.90 22 23.10 17.0 17.5 650 0.25 1 16.7 68 1SMB5934 934B 22.80 24 25.20 15.6 19 700 0.25 1 18.2 63 1SMB5935 935B 25.65 27 28.35 13.9 23 700 0.25 1 20.6 56 1SMB5936 936B 28.50 30 31.50 12.5 26 750 0.25 1 22.8 50 1SMB5937 937B 31.35 33 34.65 11.4 33 800 0.25 1 25.1 45 1SMB5938 938B 34.20 36 37.80 10.4 38 850 0.25 1 27.4 42 1SMB5939 939B 37.05 39 40.95 9.6 45 900 0.25 1 29.7 38 1SMB5940 940B 40.85 43 45.15 8.7 53 950 0.25 1 32.7 35 1SMB5941 941B 44.65 47 49.35 8.0 67 1000 0.25 1 35.8 32 1SMB5942 942B 48.45 51 53.55 7.3 70 1100 0.25 1 38.8 29 1SMB5943 943B 53.20 56 58.80 6.7 86 1300 0.25 1 42.6 27 1SMB5944 944B 58.90 62 65.10 6.0 100 1500 0.25 1 47.1 24 1SMB5945 945B 64.60 68 71.40 5.5 120 1700 0.25 1 51.7 22 1SMB5946 946B 71.25 75 78.75 5.0 140 2000 0.25 1 56.0 20 1SMB5947 947B 77.90 82 86.10 4.6 160 2500 0.25 1 62.2 18 1SMB5948 948B 86.45 91 95.55 4.1 200 3000 0.25 1 69.2 16 1SMB5949 949B 95.00 100 105.00 3.7 250 3100 0.25 1 76.0 15 1SMB5950 950B 104.50 110 115.50 3.4 300 4000 0.25 1 83.6 13 1SMB5951 951B 114.00 120 126.00 3.1 360 4500 0.25 1 91.2 12 1SMB5952 952B 123.50 130 136.50 2.9 450 5000 0.25 1 98.8 11 1SMB5953 953B 142.50 150 157.50 2.5 600 6000 0.25 1 114.0 10 1SMB5954 954B 152.00 160 168.00 2.3 700 6500 0.25 1 121.6 9 1SMB5955 955B 171.00 180 189.00 2.1 900 7000 0.25 1 136.8 8 1SMB5956 956B 190.00 200 210.00 1.9 1200 8000 0.25 1 152.0 7 Notes: 1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5% 2. Zener voltage (Vz) measurement: Nominal Zener voltage is measured with the device junction in thermal equilibrium with ambient temperature 25°C 3. Zener impedance (Zz) derivation : ZZT and ZZK are measured by dividing the AC voltage drop across the device by the AC current applied. 4. The specified limits are for Iz(AC) = 0.1 Iz(DC) with the AC frequency = 60Hz 2 Version: M2102 1SMB5926 – 1SMB5956 Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING 1SMB59x DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 11V(1SMB5926) to 200V(1SMB5956) 3 Version: M2102 1SMB5926 – 1SMB5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Steady State Power Derating Fig.2 Maximum Surge Power MAXIMUM POWER DISSIPATION (W) 4 1000 PEAK SURGE POWER (W) 3 TL 2 1 TA 0 0 25 50 75 100 125 100 10 150 0 TEMPERATURE(°C) 100 Fig.4 Zener Voltage vs. Temperature Coefficient 100 TEMPERATURE COEFFICIENT (mV/°C) TEMPERATURE COEFFICIENT (mV/°C) 10 PULSE WIDTH(ms) Fig.3 Zener Voltage vs. Temperature Coefficient 10 9 8 7 6 5 4 3 2 1 0 -1 -2 -3 -4 1 Vz@IZT 2 3 4 5 6 7 8 9 10 11 Vz@IZT 10 10 12 100 ZENER VOLTAGE (V) ZENER VOLTAGE(V) 4 Version: M2102 1SMB5926 – 1SMB5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Vz = 3.3V - 10 V Fig.6 Vz = 12V - 82 V 100 ZENER CURRENT (mA) ZENER CURRENT (mA) 100 10 1 10 1 0.1 0.1 0 1 2 3 4 5 6 7 8 9 0 10 10 ZENER VOLTAGE (V) Fig.7 Effect Of Zener Voltage 20 30 40 50 60 70 ZENER VOLTAGE (V) 90 100 Fig.8 Effect Of Zener Current 1000 1000 DYNAMIC IMPEDANCE (Ω) Vz=150V DYNAMIC IMPEDANCE (Ω) 80 Iz(dc) = 1mA 100 10mA 10 100 Iz(rms)=0.1 Iz(dc) 91V 62V 10 22V 12V 20mA 1 6.8V 1 10 100 0.1 1 10 100 1000 ZENER CURRENT(mA) ZENER VOLTAGE(V) 5 Version: M2102 1SMB5926 – 1SMB5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.9 Capacitance Curve Fig.10 Typical Pulse Rating Curve 10 1000 100 PEAK POWER (KW) CAPACITANCE(pF) MEASURED@ ZERO BIAS MEASURED @ Vz/2 10 1 10 NONREPETITIVE EXPONENTIAL PULSE WAVEFORM 1 0.1 0.01 100 0.01 0.1 BREAKDOWN VOLTAGE (V) 1 10 PULSE WIDTH (ms) Fig.11 Pulse Waveform Fig.12 Pulse Waveform 120 Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM 120 110 PEAK PULSE CURRENT (%) PEAK PULSE CURRENT (%) 140 Rise time tr=10μs to 100% 100 Peak value IPPM 80 Half value-IPPM/2 60 40 10/1000μs, waveform 20 0.5 90 0.9 IPEAK 80 70 60 0.5 IPEAK 50 40 30 t = 8μs 20 10 td 0 0 8/20 μs WAVEFORM AS DEFINED BY ANSI C62.1 AND IEC 801.5 100 1 1.5 2 2.5 0.1 IPEAK 0 3 0 TIME (ms) 0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.1 TIME(ms) 6 Version: M2102 1SMB5926 – 1SMB5956 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 7 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: M2102 1SMB5926 – 1SMB5956 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8 Version: M2102
1SMB5930HM4G
物料型号:1SMB5926 – 1SMB5956,由台湾半导体生产。
器件简介:这些是3瓦特、11伏至200伏的表面安装式齐纳二极管,具有自动放置的理想特性、玻璃钝化芯片结、低电感、符合RoHS标准和无卤素。
引脚分配:文档中未明确提供引脚分配图,但通常齐纳二极管有两个引脚,阳极和阴极。
参数特性: - 工作电压范围:11V 至 200V - 测试电流:1.9mA 至 34.1mA - 总功率:3瓦特 - 最大结温:150摄氏度 - 封装类型:DO-214AA (SMB) - 配置:单芯片
功能详解:适用于开关电源(SMPS)、适配器、照明应用和板载DC/DC转换器。
应用信息:适用于开关模式电源供应、适配器、照明应用和板上DC/DC转换器。
封装信息:封装类型为DO-214AA (SMB),封装材料满足UL 94V-0可燃性等级,端子为镀锡的引线,可焊接,符合J-STD-002标准。
1SMB5930HM4G 价格&库存
很抱歉,暂时无法提供与“1SMB5930HM4G”相匹配的价格&库存,您可以联系我们找货
