SSL24 R5G
SSL24 R5G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE SCHOTTKY 40V 2A DO214AA
SSL24 R5G 数据手册
SSL22 – SSL24 Taiwan Semiconductor 2A, 20V - 40V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 2 A VRRM 20 - 40 V IFSM 80 A TJ MAX 125 °C Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Monitor TV MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.093g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SSL22 SSL23 SSL24 SL22 SL23 SL24 UNIT Repetitive peak reverse voltage VRRM 20 30 40 V Reverse voltage, total rms value VR(RMS) 14 21 28 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 2 A IFSM 80 A TJ - 55 to +125 °C Storage temperature TSTG - 55 to +150 °C 1 Version: L2102 SSL22 – SSL24 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 70 °C/W Junction-to-lead thermal resistance RӨJL 25 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) Reverse current @ rated VR (2) SSL22 SSL23 SSL24 CONDITIONS SYMBOL TYP MAX UNIT IF = 2A, TJ = 25°C VF - 0.41 V TJ = 25°C IR - 400 µA TJ = 100°C IR - 50 mA - 60 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SSL2x DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 20V(SSL22) to 40V(SSL24) 2 Version: L2102 SSL22 – SSL24 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 3 2 1 100 f=1.0MHz Vslg=50mVp-p 0 10 25 50 75 100 0.1 125 1 Fig.4 Typical Forward Characteristics 100 1 TJ=75°C INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics TJ=100°C 0.1 TJ=25°C 0.01 0 100 REVERSE VOLTAGE (V) LEAD TEMPERATURE (°C) 10 10 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 1 Pulse width=300μs 1% duty cycle 0.1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 FORWARD VOLTAGE (V) 3 Version: L2102 SSL22 – SSL24 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 100 8.3ms single half sine wave 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: L2102 SSL22 – SSL24 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: L2102 SSL22 – SSL24 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2102
SSL24 R5G 价格&库存
很抱歉,暂时无法提供与“SSL24 R5G”相匹配的价格&库存,您可以联系我们找货
