SRAF1620 – SRAF16100
Taiwan Semiconductor
16A, 20V - 100V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for over-voltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
16
A
VRRM
20 - 100
V
IFSM
275
A
TJ MAX
125, 150
°C
Package
ITO-220AC
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: ITO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak revers voltage
VRRM
Reverse voltage total rms value
VR(RMS)
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Critical rate of rise of off-state
voltage
Junction temperature
Storage temperature
SRAF SRAF SRAF SRAF SRAF SRAF SRAF
UNIT
1620 1630 1640 1650 1660 1690 16100
1620
1630
1640
1650
1660
1690 16100
40
50
60
90
100
V
14
21
28
35
42
63
70
V
IF
16
A
IFSM
275
A
dv/dt
10,000
V/µs
TJ
-55 to +125
TSTG
-55 to +150
-55 to +150
1
°C
°C
Version: J2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
4
°C/W
Junction-to-case resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
SRAF1620
SRAF1630
SRAF1640
SRAF1650
SRAF1660
SRAF1690
SRAF16100
SRAF1620
SRAF1630
SRAF1640
SRAF1650
SRAF1660
SRAF1690
SRAF16100
SRAF1620
SRAF1630
SRAF1640
SRAF1650
SRAF1660
SRAF1690
SRAF16100
SRAF1620
SRAF1630
SRAF1640
SRAF1650
SRAF1660
SRAF1690
SRAF16100
IF = 16A, TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.70
V
0.92
V
500
µA
100
µA
15
mA
10
mA
mA
mA
5
mA
TJ = 25°C
TJ = 100°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
SRAF16x
ITO-220AC
50 / Tube
SRAF16xH
ITO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 20V(SRAF1620) to 100V(SRAF16100)
2. “H” means AEC-Q101 qualified
2
Version: J2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
SRAF1650-16100
16
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
SRAF1620-1640
8
SRAF1620-1640
1000
SRAF1650-16100
4
f=1.0MHz
Vsig=50mVp-p
100
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
1
TJ=75°C
0.1
TJ=25°C
0.01
30
40
50
60
70
80
90
100
100
10
SRAF1620-1640
1
UF1DLW
SRAF1650-1660
10
TJ=125°C
TJ=25°C
0.1
(A)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=100°C
1
0.01
SRAF1690-16100
0.1
0.001
0.10.30.2 0.4
0.3 0.5
0.4
Pulse width 300μs
Pulse width
1% duty cycle
0.5
0.6
0.6
0.7 0.70.8 0.80.90.9 1 1
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Maximum Non-Repetitive Forward Surge Current
300
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
10
10
275
250
225
200
175
150
125
100
75
50
25
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: J2105
1.2
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: J2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: J2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: J2105
很抱歉,暂时无法提供与“SRAF1620 C0G”相匹配的价格&库存,您可以联系我们找货
