SS320LW RVG
SS320LW RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123W(CFP3)
SS320LW RVG 数据手册
SS34LW – SS320LW Taiwan Semiconductor 3A, 40V - 200V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for over-voltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 3 A VRRM 40 - 200 V IFSM 80 A TJ MAX 125, 150 °C Package SOD-123W Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123W Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.016g (approximately) SOD-123W ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SS34 LW SS36 LW SS310 LW SS315 LW SS320 LW 34LW 36LW 30LW 3ALW 3BLW UNIT Repetitive peak reverse voltage VRRM 40 60 100 150 200 V Reverse voltage, total rms value VR(RMS) 28 42 70 105 140 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 80 A TJ - 55 to +125 - 55 to +150 °C Storage temperature TSTG - 55 to +125 - 55 to +150 °C 1 Version: C2103 SS34LW – SS320LW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 20 °C/W Junction-to-ambient thermal resistance RӨJA 75 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL SS34LW SS36LW Forward voltage (1) Reverse current @ rated VR (2) SS310LW SS315LW SS320LW SS34LW SS36LW SS310LW SS315LW SS320LW IF = 3A, TJ = 25°C TJ = 25°C VF IR TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 200 µA - 20 µA - 10 µA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SS3xLW SOD-123W 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 40V(SS34LW) to 200V(SS320LW) 2 Version: C2103 SS34LW – SS320LW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SS310LW SS36LW - SS320LW 3 CAPACITANCE (pF) 2 SS34LW 1 0 25 50 75 100 125 100 f=1.0MHz Vsig=50mVp-p 10 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) SS310LW 1 TJ=125°C 0.1 0.01 TJ=25°C 0.001 30 40 50 60 70 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 SS310LW UF1DLW 1 TJ=125°C 1 0.1 TJ=25°C 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 FORWARD VOLTAGE (V) 1.1 Fig.5 Maximum Non-Repetitive Forward Surge Current 90 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 4 80 8.3ms single half sine wave 70 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: C2103 1.2 SS34LW – SS320LW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123W SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code YW = Date Code F = Factory Code Version: C2103 SS34LW – SS320LW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2103
SS320LW RVG 价格&库存
很抱歉,暂时无法提供与“SS320LW RVG”相匹配的价格&库存,您可以联系我们找货
