1N5392G R0G
1N5392G R0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    DIODE GEN PURP 100V 1.5A DO204AC
1N5392G R0G 数据手册
1N5391G – 1N5399G Taiwan Semiconductor 1.5A, 50V - 1000V Standard Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Glass passivated chip junction High efficiency, Low VF High current capability High surge current capability Low power loss RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1.5 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Junction temperature Storage temperature SYMBOL 1N 1N 1N 1N 1N 1N 1N UNIT 5391G 5392G 5393G 5395G 5397G 5398G 5399G 1N 1N 1N 1N 1N 1N 1N 5391G 5392G 5393G 5395G 5397G 5398G 5399G VRRM 50 100 200 400 600 800 1000 V VR(RMS) 35 70 140 280 420 560 700 V IF 1.5 A IFSM 50 A TJ -55 to +150 °C TSTG -55 to +150 °C 1 Version: F2105 1N5391G – 1N5399G Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 65 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage (1) Reverse current @ rated VR (2) CONDITIONS 1N5391G 1N5392G 1N5393G 1N5395G IF = 1.5A, TJ = 25°C 1N5397G 1N5398G 1N5399G TJ = 25°C Junction capacitance TJ = 125°C 1MHz, VR = 4.0V SYMBOL TYP MAX UNIT - 1.1 V - 1.0 V - 5 µA - 100 µA 15 - pF VF IR CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING 1N539xG DO-204AC (DO-15) 3,500 / Tape & Reel 1N539xG A0G DO-204AC (DO-15) 1,500 / Ammo box 1N539xGH DO-204AC (DO-15) 3,500 / Tape & Reel 1N539xGHA0G DO-204AC (DO-15) 1,500 / Ammo box Notes: 1. "x" defines voltage from 50V (1N5391G) to 1000V (1N5399G) 2. “H” means AEC-Q101 qualified 2 Version: F2105 1N5391G – 1N5399G Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 1.5 CAPACITANCE (pF) 1 0.5 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 1010 UF1DLW 1N5393G-1N5399G 1 TJ=125°C TJ=25°C 10.1 1N5391G-1N5392G 0.01 0.1 0.001 0.70.3 Pulse Pulse width width 300μs 300μs 1% duty cycle Pulse width 0.8 0.4 0.9 0.5 0.6 1 0.7 1.10.8 1.2 0.9 11.3 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 100 1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: F2105 1.2 1N5391G – 1N5399G Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: F2105 1N5391G – 1N5399G Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: F2105
1N5392G R0G 价格&库存
很抱歉,暂时无法提供与“1N5392G R0G”相匹配的价格&库存,您可以联系我们找货
