SRAF890HC0G
SRAF890HC0G
    TAIWANSEMICONDUCTOR(台半)
    TO220-2
    DIODE SCHOTTKY 90V 8A ITO220AC
SRAF890HC0G 数据手册
SRAF820 – SRAF8150 Taiwan Semiconductor 8A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low power loss, high efficiency Guard ring for over-voltage protection High surge current capability UL Recognized File # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 8 A VRRM 20 - 150 V IFSM 150 A TJ MAX 125, 150 °C Package ITO-220AC Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● ● Case: ITO-220AC Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Mounting torque: 0.56 N⋅m maximum Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 1.70g (approximately) ITO-220AC ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Repetitive peak reverse voltage Reverse voltage total rms value Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage Junction temperature Storage temperature SRAF 820 SRAF 820 SRAF 830 SRAF 830 SRAF 840 SRAF 840 SRAF 850 SRAF 850 SRAF 860 SRAF 860 SRAF 890 SRAF 890 SRAF 8100 SRAF 8100 VRRM 20 30 40 50 60 90 100 150 V VR(RMS) 14 21 28 35 42 63 70 105 V SYMBOL SRAF UNIT 8150 SRAF 8150 IF 8 A IFSM 150 A dv/dt 10,000 V/µs TJ -55 to +125 -55 to +150 TSTG -55 to +150 1 °C °C Version: K2105 SRAF820 – SRAF8150 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-case resistance SYMBOL TYP UNIT RӨJC 5 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SRAF820 SRAF830 SRAF840 SRAF850 SRAF860 SRAF890 SRAF8100 SRAF8150 SRAF820 SRAF830 SRAF840 SRAF850 SRAF860 SRAF890 SRAF8100 SRAF8150 SRAF820 SRAF830 SRAF840 SRAF850 SRAF860 SRAF890 SRAF8100 SRAF8150 SRAF820 SRAF830 SRAF840 SRAF850 SRAF860 SRAF890 SRAF8100 SRAF8150 IF = 8A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 15 mA - 10 mA - - mA - - mA - 5 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SRAF8x ITO-220AC 50 / Tube SRAF8xH ITO-220AC 50 / Tube Notes: 1. “x” defines voltage from 20V(SRAF820) to 150V(SRAF8150) 2. “H” means AEC-Q101 qualified 2 Version: K2105 SRAF820 – SRAF8150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 SRAF850-8150 5 CAPACITANCE (pF) 4 3 SRAF820-840 2 1000 SRAF820-860 1 0 f=1.0MHz Vsig=50mVp-p 100 25 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 1 TJ=75°C 0.01 TJ=25°C 0.001 20 30 40 50 60 70 80 90 100 10 10 SRAF820-840 1 UF1DLW SRAF850-860 TJ=125°C TJ=25°C 10.1 SRAF890-8100 0.01 SRAF8150 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1 1.1 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Fig.5 Maximum Non-Repetitive Forward Surge Current 165 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=100°C 10 100 Fig.4 Typical Forward Characteristics 100 0.1 10 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 SRAF890-8150 (A) AVERAGE FORWARD CURRENT (A) 6 150 135 120 105 90 75 60 45 30 15 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: K2105 1.2 SRAF820 – SRAF8150 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: K2105 SRAF820 – SRAF8150 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS ITO-220AC MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: K2105 SRAF820 – SRAF8150 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2105
SRAF890HC0G 价格&库存
很抱歉,暂时无法提供与“SRAF890HC0G”相匹配的价格&库存,您可以联系我们找货
