MBRF20H100CT – MBRF20H200CT
Taiwan Semiconductor
20A, 100V - 200V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
A
VRRM
100 - 200
V
IFSM
150
A
TJ MAX
175
°C
Package
ITO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
MBRF
MBRF
MBRF
20H100CT
20H150CT
20H200CT
MBRF
20H100CT
MBRF
20H150CT
MBRF
20H200CT
UNIT
Repetitive peak reverse voltage
VRRM
100
150
200
V
Reverse voltage, total rms value
VR(RMS)
70
105
140
V
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
(1)
Peak repetitive reverse surge current
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
Critical rate of rise of off-state voltage
Junction temperature
Storage temperature
Notes:
1. tp = 2.0μs, 1.0KHz
IF
A
IFSM
150
A
IRRM
1.0
0.5
A
IFRM
A
dv/dt
10,000
V/µs
TJ
TSTG
-55 to +175
-55 to +175
°C
°C
1
Version: I2105
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
SYMBOL
TYP
UNIT
RӨJC
3.5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MBRF20H100CT
MBRF20H150CT IF = 10A,TJ = 25°C
MBRF20H200CT
MBRF20H100CT
MBRF20H150CT IF = 20A,TJ = 25°C
Forward voltage per diode
(1)
MBRF20H200CT
TYP
MAX
UNIT
0.85
V
0.88
V
0.95
V
0.97
V
0.75
V
0.85
V
VF
MBRF20H100CT
MBRF20H150CT IF = 10A,TJ = 125°C
MBRF20H200CT
MBRF20H100CT
MBRF20H150CT IF = 20A,TJ = 125°C
MBRF20H200CT
Reverse current @ rated VR per diode
(2)
TJ = 25°C
IR
5
µA
TJ = 125°C
IR
2
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBRF20HxCT
ITO-220AB
50 / Tube
MBRF20HxCTH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 100V(MBRF20H100CT) to 200V(MBRF20H200CT)
2. “H” means AEC-Q101 qualified
2
Version: I2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
CAPACITANCE (pF)
15
10
100
5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
150
0.1
175
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
1
TJ=125°C
0.1
TJ=75°C
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
10
90 100
100 10
UF1DLW
1
TJ=125°C
10
TJ=125°C
TJ=25°C
0.1
TJ=25°C
1
0.01
0.1
0.001
0.1 0.3 0.3
0.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
Pulse width
1% duty cycle
0.5
0.5
0.60.7 0.7 0.90.8
1.1
0.9
11.3 1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
165
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
0.01
10
REVERSE VOLTAGE (V)
150
135
8.3ms single half sine wave
120
105
90
75
60
45
30
15
10
100
NUMBER OF CYCLES AT 60 Hz
3
(A)
AVERAGE FORWARD CURRENT (A)
25
Version: I2105
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: I2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: I2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2105
很抱歉,暂时无法提供与“MBRF20H100CT C0G”相匹配的价格&库存,您可以联系我们找货
