SR115 R1G
SR115 R1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE SCHOTTKY 150V 1A DO204AL
SR115 R1G 数据手册
SR102 – SR115 Taiwan Semiconductor 1A, 20V - 150V Schottky Barrier Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Low forward voltage drop Low power loss, high efficiency Guard ring for overvoltage protection High surge current capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 1 A VRRM 20 - 150 V IFSM 30 A TJ MAX 125, 150 °C Package DO-204AL (DO-41) Configuration Single die ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.330g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage SR SR SR 102 103 104 SR SR SR 102 103 104 20 30 40 14 21 28 SR SR SR SR SR UNIT 105 106 109 110 115 SR SR SR SR SR 105 106 109 110 115 50 60 90 100 150 V 35 42 63 70 105 V IF 1 A IFSM 30 A dv/dt 10,000 V/µs Junction temperature TJ Storage temperature TSTG -55 to +125 -55 to +150 -55 to +150 1 °C °C Version: G2104 SR102 – SR115 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 90 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR (2) SR102 SR103 SR104 SR105 SR106 SR109 SR110 SR115 SR102 SR103 SR104 SR105 SR106 SR109 SR110 SR115 SR102 SR103 SR104 SR105 SR106 SR109 SR110 SR115 SR102 SR103 SR104 SR105 SR106 SR109 SR110 SR115 IF = 1A, TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 10 mA - 5 mA - - mA - - mA - - mA - 2 mA TJ = 25°C TJ = 100°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE PACKING SR1x DO-204AL (DO-41) 5,000 / Tape & Reel SR1x A0G DO-204AL (DO-41) 3,000 / Ammo box SR1xH DO-204AL (DO-41) 5,000 / Tape & Reel SR1xHA0G DO-204AL (DO-41) 3,000 / Ammo box Notes: 1. “x” defines voltage from 20V (SR102) to 150V (SR115) 2. “H” means AEC-Q101 qualified 2 Version: G2104 SR102 – SR115 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SR102-SR104 CAPACITANCE (pF) SR105 - SR115 1 SR105-SR106 100 SR109-SR115 SR102 - SR104 0 f=1.0MHz Vsig=50mVp-p 10 25 50 75 100 125 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C TJ=75°C 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 90 100 10 10 SR102-SR104 UF1DLW 1 TJ=125°C SR105-SR106 TJ=25°C 10.1 SR109-SR110 0.01 SR115 Pulse width 300μs Pulse width 1% duty cycle 0.1 0.001 0.2 0.30.4 0.40.6 0.50.8 0.61.0 0.7 1.2 0.8 1.4 0.9 1.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 35 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 10 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 (A) AVERAGE FORWARD CURRENT (A) 2 30 8.3ms single half sine wave 25 20 15 10 5 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: G2104 1.2 SR102 – SR115 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 10 1 0.1 0.01 0.1 1 10 100 PULSE DURATION (s) 4 Version: G2104 SR102 – SR115 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: G2104 SR102 – SR115 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: G2104
SR115 R1G
物料型号:SR102至SR115,是台湾半导体生产的肖特基二极管。
器件简介:这些二极管具有低正向电压降、低功耗、高效率,适用于开关电源、适配器和DC-DC转换器等应用。
引脚分配:文档中提到了阳极和阴极的标记,但没有详细说明具体的引脚分配
参数特性:包括正向电流IF为1A,反向重复峰值电压VRRM从20V至150V不等,最大结温TJMAX从125°C至150°C不等,封装为DO-204AL(DO-41)。
功能详解:文档提供了关键参数表、绝对最大额定值、热性能、电气规格等详细信息,以及特性曲线图,如正向电流降额曲线、典型结电容、典型反向特性、典型正向特性和最大非重复正向浪涌电流等。
应用信息:适用于开关模式电源(SMPS)、适配器、DC到DC转换器等。
封装信息:封装类型为DO-204AL(DO-41),符合UL 94V-0阻燃等级,终端为纯锡镀层引线,符合J-STD-002可焊性标准,并通过JESD 201 class 2须根测试。
SR115 R1G 价格&库存
很抱歉,暂时无法提供与“SR115 R1G”相匹配的价格&库存,您可以联系我们找货
