MBRF2535CT – MBRF25150CT
Taiwan Semiconductor
25A, 35V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
UL Recognized File # E-326243
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
25
A
VRRM
35 - 150
V
IFSM
200
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.70g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
MBRF MBRF MBRF MBRF MBRF MBRF MBRF
PARAMETER
SYMBOL
2535
2545
2550
2560
CT
CT
CT
CT
2590 25100 25150 UNIT
CT
CT
CT
2535
2545
2550
2560
2590 25100 25150
CT
CT
CT
CT
CT
CT
CT
Marking code on the device
Repetitive peak reverse voltage
VRRM
35
45
50
60
90
100
150
V
Reverse voltage, total rms value
VR(RMS)
24
31
35
42
63
70
105
V
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
Critical rate of rise of off-state
voltage
Junction temperature
IF
25
A
IFSM
200
A
IFRM
25
A
dv/dt
10,000
V/µs
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
Storage temperature
1
Version: L2105
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
8
°C/W
Junction-to-case thermal resistance
RӨJC
1
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MBRF2535CT
MBRF2545CT
MBRF2550CT
MBRF2560CT
MBRF25100CT
MBRF25150CT
MBRF2535CT
MBRF2545CT
MBRF2550CT
MBRF2590CT
(1)
MBRF25150CT
MBRF2545CT
MBRF2550CT
V
0.75
V
0.85
V
0.95
V
0.82
V
V
0.92
V
1.02
V
V
0.65
V
0.75
V
0.92
V
0.73
V
V
0.88
V
0.98
V
IF = 12.5A,TJ = 125°C
MBRF2590CT
MBRF25100CT
MBRF25150CT
MBRF2535CT
MBRF2545CT
MBRF2550CT
MBRF2560CT
VF
MBRF2535CT
MBRF2560CT
UNIT
IF = 25A,TJ = 25°C
MBRF25100CT
Forward voltage per diode
MAX
IF = 12.5A,TJ = 25°C
MBRF2590CT
MBRF2560CT
TYP
IF = 25A,TJ = 125°C
MBRF2590CT
MBRF25100CT
MBRF25150CT
2
Version: L2105
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
2
mA
100
µA
15
mA
10
mA
7.5
mA
5
mA
MBRF2535CT
MBRF2545CT
MBRF2550CT
MBRF2560CT
TJ = 25°C
MBRF2590CT
MBRF25100CT
Reverse current @ rated VR
per diode
(2)
MBRF25150CT
IR
MBRF2535CT
MBRF2545CT
MBRF2550CT
MBRF2560CT
TJ = 125°C
MBRF2590CT
MBRF25100CT
MBRF25150CT
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBRF25xCT
ITO-220AB
50 / Tube
MBRF25xCTH
ITO-220AB
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBRF2535CT) to 150V(MBRF25150CT)
2. “H” means AEC-Q101 qualified
3
Version: L2105
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
25
CAPACITANCE (pF)
10
1000
MBRF2535CT-2560CT
MBRF2590CT-25150CT
100
5
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
CASE TEMPERATURE (°C)
MBRF2535CT-2545CT
MBRF2550CT-25150CT
1
TJ=125°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
100
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
100010
100 1
MBRF2535CT-2545CT
MBRF2550CT-2560CT
UF1DLW
MBRF2590CT-25150CT
TJ=125°C
T =125°C
J
10
0.1
TJ=25°C
1
0.01
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.001
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
220
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.3 Typical Reverse Characteristics
10
10
REVERSE VOLTAGE (V)
200
180
160
140
120
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
4
(A)
AVERAGE FORWARD CURRENT (A)
30
Version: L2105
1.2
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: L2105
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: L2105
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: L2105
很抱歉,暂时无法提供与“MBRF25150CTHC0G”相匹配的价格&库存,您可以联系我们找货
