SRAS820 – SRAS8150
Taiwan Semiconductor
8A, 20V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
20 - 150
V
IFSM
150
A
TJ MAX
125, 150
APPLICATIONS
°C
2
Package
TO-263AB (D PAK)
Configuration
Single die
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.37g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse
voltage
Reverse voltage, total rms
value
Forward current
Surge peak forward current,
8.3ms single half sine wave
superimposed on rated load
Critical rate of rise of offstate voltage
Junction temperature
Storage temperature
SRAS SRAS SRAS SRAS SRAS SRAS SRAS SRAS
UNIT
820
830
840
850
860
890 8100 8150
820
830
840
850
860
890
8100
8150
VRRM
40
50
60
90
100
150
V
VR(RMS)
14
21
28
35
42
63
70
105
V
IF
8
A
IFSM
150
A
dv/dt
10,000
V/µs
TJ
-55 to +125
TSTG
-55 to +150
-55 to +150
1
°C
°C
Version: K2103
SRAS820 – SRAS8150
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
3
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
SRAS820
SRAS830
SRAS840
SRAS850
SRAS860
(1)
IF = 8A, TJ = 25°C
SYMBOL
VF
SRAS890
SRAS8100
SRAS8150
Reverse current @ rated VR
(2)
SRAS820
SRAS830
SRAS840
SRAS850
TJ = 25°C
SRAS860
SRAS890
SRAS8100
SRAS8150
SRAS820
SRAS830
SRAS840
SRAS850
TJ = 100°C
SRAS860
SRAS890
SRAS8100
SRAS8150
SRAS820
SRAS830
SRAS840
SRAS850
TJ = 125°C
SRAS860
SRAS890
SRAS8100
SRAS8150
TYP
MAX
UNIT
0.55
V
0.70
V
0.95
V
100
µA
5
mA
mA
mA
5
mA
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
SRAS8x
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. “x” defines voltage from 20V(SRAS820) to 150V(SRAS8150)
2
Version: K2103
SRAS820 – SRAS8150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SRAS850 - SRAS8150
8
CAPACITANCE (pF)
6
SRAS820 - SRAS840
4
100
2
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=125°C
TJ=75°C
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100 10
SRAS850 - SRAS860
10
1
SRAS820
- SRAS840
UF1DLW
TJ=125°C
TJ=25°C
0.1
1
SRAS890 - SRAS8150
0.01
0.1
0.001
0.2
Pulse width 300μs
1% duty cycle
Pulse width
0.3 0.4 0.5
0.3
0.4
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.6 0.7 0.8 0.9 1.0
0.6
0.7
0.8
0.9
1.1
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
200
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
10
0.1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
(A)
AVERAGE FORWARD CURRENT (A)
10
150
100
50
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2103
1.2
SRAS820 – SRAS8150
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: K2103
SRAS820 – SRAS8150
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2103
SRAS820 – SRAS8150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2103
很抱歉,暂时无法提供与“SRAS830HMNG”相匹配的价格&库存,您可以联系我们找货
