S15GLW RVG
S15GLW RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123W(CFP3)
S15GLW RVG 数据手册
S15DLW – S15MLW Taiwan Semiconductor 1.5A, 200V - 1000V Standard Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Ideal for automated placement Compact package size High surge current capability Low power loss, high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 1.5 A VRRM 200 - 1000 V IFSM 50 A TJ MAX 175 °C Package SOD-123W Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● General purpose MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123W Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.019g (approximately) SOD-123W ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S15DLW S15GLW S15JLW S15KLW S15MLW UNIT 15DLW 15GLW 15JLW 15KLW 15MLW Repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 140 280 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1.5 A IFSM 50 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: C2103 S15DLW – S15MLW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 29 °C/W Junction-to-ambient thermal resistance RӨJA 85 °C/W Junction-to-case thermal resistance RӨJC 31 °C/W Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 1.0A, TJ = 25°C Forward voltage IF = 1.5A, TJ = 25°C (1) IF = 1.0A, TJ = 125°C VF IF = 1.5A, TJ = 125°C Reverse current @ rated VR (2) Junction capacitance TJ = 25°C IR TJ = 125°C 1MHz, VR = 4.0V CJ TYP MAX UNIT 0.94 1.05 V 0.98 1.10 V 0.81 1.00 V 0.87 1.05 V - 1 µA - 100 µA 10 - pF Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S15xLW SOD-123W 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 200V(S15DLW) to 1000V(S15MLW) 2 Version: C2103 S15DLW – S15MLW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 1.5 CAPACITANCE (pF) 1.0 0.5 0.0 25 55 85 115 145 10 1 f=1.0MHz Vsig=50mVp-p 0.1 175 1 10 LEAD TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics 10 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (uA) Fig.3 Typical Reverse Characteristics TJ=125°C 1 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 100 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 1 1 0.1 UF1DLW TJ=125°C TJ=125°C TJ=25°C TJ=25°C 0.01 0.1 0.001 0.6 0.7 0.8 0.9 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 1.0 0.7 1.1 0.8 FORWARD VOLTAGE (V) 3 (A) AVERAGE FORWARD CURRENT (A) 2.0 1.2 0.9 1.3 1 1.1 Version: C2103 1.2 S15DLW – S15MLW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123W SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code YW = Date Code F = Factory Code Version: C2103 S15DLW – S15MLW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2103
S15GLW RVG 价格&库存
很抱歉,暂时无法提供与“S15GLW RVG”相匹配的价格&库存,您可以联系我们找货
